I looked in Chaparral & dennis kirk catalog, the sprockets are the same part # from '99 to '04, and it says they use the same chain. Other than that, I personally don't know, but the sprocket tooth count is the same on stock....good luck! :)
cyclerider105 said:
I am sure the 99 to 05 sprockets are the same. Stock chain is 525 pitch and varies in length depending on your sprocket tooth count. 110 link is standard for the 15 front and 45 tooth rear.
not only sprockets but complete cush drives(except inner and outer spacers on cush)are interchangable.
