1 - 9 of 9 Posts
Bike is "hiccuping" needles on tach & speedos shooting up & down. Gas light is popping on. Sometimes stalling out when stopped. It's an '02 w/ a Yosh slip-on. Would this be bad gas/watered down gas?
very likely an electrical problem
check voltage of battery & charging system
BANNED!!!
Make sure the battery connections are fully secure. Had a loose ground connection once cause some similar issues.
Kid Thunder,
Did you by chance experience a similar problem during full throttle? I am having an odd fuel injection issue as well on my 05 650s. The bike tends to stall when floored from a stop. Usually stalls in first, sometimes in second. I turn off the ignition and toggle the kill switch and then turn the ignition on... and it starts as usual. It is inconsistent. Perhaps we have the same problem?
+1 If the ignition system is not getting its full voltage it can act very sporadicly.
BTW run a volt test on the battery and it should be at 12.65 volts not 12. A fully charged battery is 12.65 and if it isn't charging all the way this could cause a problem
Robotben311 said:
Kid Thunder,
nope sorry i have carbs
i had a bad cell in my battery and it was making my bike jumpy. weird stuff
1 - 9 of 9 Posts
