Got the heating elements on the bars, and grips on over top of them. Now it's time to wire them up.
So, I can wire the resistor in to make them hi/lo or I can wire them so it's on/off with the resistor on the throttle side to "equalize the temperature." Who has put the resistor on the throttle element? If so, are you happy with it that way, or does the other one get too darn hot? I'm not as brave as RandyO and JBS, I put them on for those chilly morning commutes, 30 minutes in upper thirties and lower forties. Anywho, if you've done the different wattage to the elements, let me know if you think it's the best thing since sliced bread, or you hated it and switched back to the hi/lo.
Second, point me to a better (smaller and less fugly) switch. I've seen rowboat oars smaller than the paddle on that thing. Also, the big honking Red, alum and Blue label is a bit distracting. What have you all found as a better, more subtle switch? I'm leaning towards some small handlebar rocker type switch, except it costs as much as the dang kit. Show me what you're using, or where you hid the one Kimpex provided so it doesn't look like a ******* add-on. Mind you, I am a *******, just don't want my bike to look like it belongs to one.
