1 - 7 of 7 Posts
went to replace my "broken cable' and discovered the clutch release mechanism split at the cable holder allowing the cable to pop out. going to try lassoing it together with a mini hose clamp untill the new part comes
just corrosion and use over 123k, can't complain
at 123k I think pretty much anything could happen...
Eagle one
Like I said Randy......... just a reality check........ before you invest a lot of money in the suspension........ you might want to look for a bike with 100,000 less miles on it........
if I get another bike, it will have 123k less miles on it
In my case, it was a loosened front sprocket which caused the chain to rub this very part (nearly) through. You might have a look in that direction, too.
Ciao
Jan
Ciao
Jan
no, where this broke is nowwhere near the sprocket, it would have to damage the cable first, just plain worn out, cable is fine, sprocket is tight
1 - 7 of 7 Posts
