I’ve moved my hand controls around to match a new body position and now the hose connecting the reservoir and master cylinder is a little bit short.
So I wonder, what kind of hose is appropriate for connecting the reservoir and master cylinder? I don’t think it needs to be high pressure hose, but it shouldn’t break down when exposed to DOT4 fluid either. I'm also not positive what size hose should be used...and I guess new hose clamps would be needed?
:::ANSWER:::
Stock tubing is 8mm = 5/16" + 0.003" (inside diameter) and it needs to be chemically resistant to brake fluid.
So, the best options are:
Targon 2075 (5/16 ID) $2.20/foot, part number: 5103K18, http://www.mcmaster.com/#5103k18/=1cbky9
Targon 2275 (5/16 ID) $2.32/foot, part number: 5466K15, http://www.mcmaster.com/#5466k15/=1cbnaf
Hose clamps are still under investigation.
:::ANSWER:::
