1 - 10 of 10 Posts
Discussion Starter · #4 · (Edited)
Zuki has one on his 2nd gen. Although his bike has a GSXR swap and the install will be different, he'll probably have a few tips for you.
Is Zuki his full member name? Searched Zuki in the member list and there are way too many pages to look through.
For those who have installed one of these gauges, what size adapters did you use for the oil and water temp sensors?
Gauge installed and working well. Just need to check the speedo and tach accuracy. FYI, setting on the gauge for the rpm's should be 4 and 1, not 4 and 2. The dual spark plugs on the 2009 cause the gauge to read the rpms at about half the true value when set to 4-2.
Still not sure about the water sensor adapter though...
1 - 10 of 10 Posts
