I'm hoping I have all the appropriate associated hardware, not really sure what it should be. He said he gave me all the bolts, but if I'm missing some I guess I'll pick them up at the dealer or somethin. I'll have to fab a bracket for my headlight and gauge cluster I think, but I can put the bike together without it for right now.Clip-ons
Triple clamps
Forks
Axle
Wheel
Calipers
Rotors
Fender
And all associated hardware.*
If you have a 1999 - 2002 SV then you also need a top bearing kit from TWF and upper bearing dust cover 51643-33E00.*
You DO NOT need the controls, levers, perches, hoses or cables. If you're using a radial front end then you need a radial master cylinder, otherwise you can keep using your SV master cylinder.
