My 02 SV is a trackday only. Has a stock clutch pack. I replaced the clutch cable last fall. Two trackdays ago, I was looking it over and noticed where the cable goes into the cable adjuster by the clutch lever(at the clip on) that the screw part that goes into the main body was broken off at the end. I took another adjuster and lock thumb wheel and replaced it. Did another track day, all was good. I was looking the bike over a couple of days ago, and this adjuster is broken where the cable sheath sits in the adjuster screw. Same as last time. I think the threads in the body are probably worn, but think I can get by with getting a std Suzuki replacement, or do I have to go aftermarket to clear this problem up?
TIA.
Banned
He has different cables? Now they tell me... same with the teflon lube.
