1 - 8 of 8 Posts
I am looking to turn some aftermarket billet parts black through anodizing. Anyone tried this themselves? Its a handful of random parts (cfm rearsets, vortex clipons, shock bottle holder). Is there mail order place that does this for a reasonable cost? Anyone know of a place in or around Chicago?
Thank you
Awesome. Thanks guys. I think I'll give it a try at home. Time to secure some chemicals.
You'll be dealing with some nasty stuff. Caustic soda to strip parts, sulfuric acid for anodizing. Nickle Acetate for sealing. You will need a DC power source as well. I'm not sure what this guy recommends, but when I did anodizing back in the 90's, the baths were set at 14-18 volts. Just to warn you, getting a deep, even black color is not easy, even with a full anodizing shop setup. I'd probably look around for a local anodizing shop that can do it for you.
100% agree - after watching my Dad do his own plating (which is similar, but not the same), I will just outsource anodizing - it's nasty stuff.
FWIW..I tried doing my own anodizing as well. I did NOT get it right with a couple attempts. I think in all cases, my fail method was not enough amps from my cheapy battery charger, as well as not maintaining a correct bath temperature. Since it is nasty stuff, I was doing it outside at the end of winter/start of spring last year..it was 50 °F ish out.
1 - 8 of 8 Posts
