1 - 7 of 7 Posts
Hello all, can someone tell me where i can find the air mixture screw on a Mikuni BDSR39 carb?
I have a 2005 Hyuosung GV 650 with a pair of these carbs and its running way rich and rough idle and popping exhaust, id like to try the factory 2 and a half turns out and go from there but don't have any diagrams on where the air mixture screw is on the model.
If anyone can point me in the right direction or if you have pics even better.
Thanks in advance
Marty :)
I don't know exactly what carbs SV has but they're 39mm Mikunis for sure so likely same carbs.
On almost all carbs idle mixture screw is on bottom, near float bowl.
note that from the factory there may be a plug over it
1 - 7 of 7 Posts
