More pics...
I put JB Weld on the tank where the pinhole leaks were at. I will let it cure for a couple of days.
I cut a spacer using the metal sleeve that was on the shock rubber that I had to remove to install them. The spacer goes on the left side where the tank bolts on the rear. There was an extra locknut that was used as a spacer, but I am replacing the bolts so the .350 spacer I cut will work!
