4781 - 4790 of 4790 Posts
Chief Greeter
Discussion Starter · #4,781 ·
I checked the gas tank and it is clean and dry! I removed the carb and had to get a special tool to get to the top nut...
Motor vehicle Automotive fuel system Gas Auto part Automotive exterior
Using a 90 degree racket wrench with vise-grip pliers got the job done!
Carb is on the right side of motor, and on the left side is the ignition switch, choke and the horn...
Bicycle part Rim Cameras & optics Automotive tire Wood
The horn connection was broken so i soldered it back together.
Fuel tank Tire Wheel Automotive tire Automotive lighting
So I had been on a buying frenzy, stuff is still coming in the mail!
Chief Greeter
Discussion Starter · #4,782 · (Edited)
6-14-22 I got all the stuff I ordered, spent $1100 and I still have a few more items to buy.
Tire Hood Automotive tire Motor vehicle Automotive lighting
I removed the coil so I could replace the crossover tube under the gas tank...
Hood Automotive tire Automotive design Motor vehicle Automotive lighting
Got a can of carb cleaner, going to rebuild the original one! (y)
Chief Greeter
Discussion Starter · #4,783 ·
6-16-22 Johnny came over for the tire installation...
Road surface Asphalt Automotive tire Sidewalk Urban design
Tire Wheel Shoe Bicycle wheel Bicycle tire
This is a must have tool!
Wheel Tire Automotive tire Tread Motor vehicle
Tire Wheel Motor vehicle Automotive lighting Automotive tire
Front tire installed, and a surprise for us on the rear tire! Steve had changed the original 18" rim from his Sportster and ran a 16" rim like the Superglide Harleys!
So I was able to get a matching rear tire now that I need a 16" and mailed the 18" stuff back to JPCycles.
Chief Greeter
Discussion Starter · #4,786 · (Edited)
6-18-22 installed the front tire, now to work on the front brake rebuild...
Tire Wheel Fuel tank Motor vehicle Automotive tire
So I was planning to run the front fender...
Tire Wheel Motor vehicle Automotive tire Vehicle
Thought I could leave the fender on when installing the tire but no way it would not fit?!
Wheel Tire Bicycle tire Automotive tire Synthetic rubber
Wheel Tire Bicycle tire Automotive tire Vehicle brake
So tried to install the fender with the tire on and you can see I almost have the brackets where they bolt to the forks and they are right against the tire?!
So now I know why the front fender isn't on the bike - besides I really like the chopper look! (y)
Automotive tire Motor vehicle Wood Bumper Gas
After finding out the original horn doesn't work I decided to relocate the new "Mini Chopper" horn (they had me sold at mini chopper).
Crankset Automotive tire Motor vehicle Automotive lighting Bicycle part
Was able to make an L bracket bolted to the horn bracket and mount it to an existing hole on the motor mount bracket! So the left side will have the ignition switch and choke but nothing under it so you will see the cylinder heads!
Hood Automotive lighting Automotive design Textile Mesh
Area circled will be removed.
Chief Greeter
Discussion Starter · #4,788 ·
6-20-22 I am working on the front brakes...
Product Pen Writing implement Font Line
Special tool to break the master cylinder screws on the cover!
Motor vehicle Gas Engineering Metal Auto part
Rebuilding the master cylinder and the caliper...
Eye Art Font Wall Graffiti
On this stock photo of the Sportster you can see the stock rear turn signal and the stock rear red reflector.
Wheel Tire Vehicle Automotive tire Automotive lighting
I usually run two red reflectors on the license plate frame but the frame I got only allows for bolts to fit, so I found a place on the side where the stock rear turn signal mounts and glued them in place! Going for the "Mini Chopper" look! :D
Chief Greeter
Discussion Starter · #4,790 ·
6-23-22 working on the front turn signal brackets...
Font Parallel Pattern Paper Paper product
Hand tool Wood Tool Metalworking hand tool Metal
Used the front fender bolt with a nut to clamp brackets for filing!
Bicycle tire Wheel Automotive tire Bicycle frame Motor vehicle
Automotive tire Hood Motor vehicle Automotive lighting Automotive design
Have to get a longer screw for the bracket plus washer. I will paint one to see if black will work, otherwise I may have to chrome them?!
