1 - 3 of 3 Posts
· Registered
ive got 2006 SV650s that was wrecked. got a replacement headlight for cheap the cyclops... when i tried to wire it up i somehow shorted out all the electrical sytems on my bike. checked the fuses and battery which were both fine. what could be wrong?
· Registered
I'm showing yellow is high beam. White is low beam. And black/white is ground. Is that how you wired it?
You checked fuses 1, 2 and 5?
There's also a fuse in the starter relay housing that may be the cause.
· Registered
Did you make sure you didn't blow the main fuse...it's not on the fuse box. Peek through your frame on the right had side and you should see a little enclosure. Will have a single fuse inside of it. Think that's where it is on second gens...someone can confirm I am sure.
1 - 3 of 3 Posts
