I have a couple of questions dealing with changing out the stock exhaust system on an 07. In order to remove the stock exhaust can, must you cut the exhaust pipe (past the two-pipe weld) running to the can? Is there a weld seam or joint seam under the chrome cover that sits just in front of the exhaust can? Is removing the stock exhaust a one way venture, or can it be re-installed? Any issues associated with the FI system or tuning if a different exhaust is installed?
I want to be sure I understand what I’m getting into before making any mods. Thanks.
