1 - 9 of 9 Posts
I have a '05 636 shock in mine. I forget off the top of my head what years are the same. You can check part numbers on a site like bikebandit.com
How much do you weigh?
-b
you are going to want a 05+ i know the 05 and 06 are the same don't know about the 07 on... yet earlier year will work but....
1. 05+ 636 shock is a different manufacturer...Showa maybe? Supposed to be slightly better than the older ones, but that's only from what I've read. I have an 03 on my SV and it's fine, did what it was supposed to do, and is a vast improvement over stock.
seriously how many lbs?
and I have a bunch of Pics of my install if you want them
Any 636 shock requires the battery box to be cut. I had an '04 on my SV and loved it.
If you need the 636's spring rate but don't want to cut/modify anything, get a ZX-14 shock (any year). It has the same 9.7kg/mm spring rate but doesn't require cutting the battery box. Here are a couple comparison pics I took. '04 ZX-6R 636 is red/gold, '06 ZX-14 is black/silver:
any modification or bolt up?
Mod battery box... cut it a little put a spacer under the battery you need the bottom bolt and nut for the 636 and a extra washer or two for that bolt due to spacing with the dogbones.
i had to cut off a few tabs
little more than 1 1/4" off of the bottom of the battery box
then i had to make a spacer to raise the battery to clear the shock.
then it looks like this.
hope it helps.
-B
1 - 9 of 9 Posts
