Which wire is the coil output signal?
I finally ordered up that raptor tach wire with the resistor and I was originally using the wire from the factory gauges (2nd gen) that powered the tach. Well now that wire doesn't produce enough voltage because of the resistor for the gauges (vapor) to get a signal.
I'm looking for the coil wire so that I can go directly to that instead of wrapping around the spark plug. I'm looking at the wiring diagram but I can't figure out which one it is.
I have 4 choices according to the diagram
B/O
B
O/W
W/Bl
The B/O and the O/W go to the starter button so I'm thinking they are inputs. Both other wires go to the ECM so I can't figure out how I'm supposed to get a signal unless one of the ones going to the ECM is an output. Any help is appreciated.
Also, this O/W goes into top right corner coming from the ignition coil but I don't know what the end is supposed to go to since it isn't labeled??
B/O
B
O/W
W/Bl
