The gen 3 sv650 (2016-2023) cannot be derestricted by cutting the "mode select switch" wire like the gladius can be. However you can unlock the full power with an ecu flash and tune I used woolitch racing. Alternatively you can remove the throttle plates from the electronic throttle bodies.G'day Fellas, first post. Does anyone know if the Australian Spec SV650FU is restricted in the same way as the Gladius, with a dual map ECU? Would be great to know I can release the American Spec ponies with a simple wire disconnect. I understand the Legalities etc. Thanks, Fisher. Edit: Relisted because of various typos.
Gladius wire cut doesn't work mate, it's the same as Gen3The gen 3 sv650 (2016-2023) cannot be derestricted by cutting the "mode select switch" wire like the gladius can be. However you can unlock the full power with an ecu flash and tune I used woolitch racing. Alternatively you can remove the throttle plates from the electronic throttle bodies.
