I did not fix the paint and body damage for almost a year and a half, this past winter. It was not THAT bad and I did not have the money to have a body shop do it for me. So, I got some flush mount front blinkers, made a fender eliminator, got some small rear blinkers, painted the windscreen black, and removed all the factory decals and stickers.
This past winter I decided I had enough of the scratches. I dove in head first and tackled painting the whole bike myself. I did what most would probably consider to be the wrong thing....I used rattle can paint. I took off all the parts, sanded, bondo'd and fiberglassed as needed, sanded, primered, painted, and then cleared with several coats. It only took a couple afternoons to finish. I used grey automotive primer, Krylon Satin Black, and Satin Clear engine enamel. It turned out great! The engine enamel as clear was for its gas resistant properties. I have gotten a few drops of gas on the tank and absolutely no eating into the paint at all. There are a few tiny chips here and there from bugs and rocks while riding over the summer. The finish is not "perfect" and has a texture to it. I was going for a hammered look to help hide some of the imperfections and it came out exactly that. I also love satin black vehicles, so there is little shine to the fnish, but that is what I was going for.
Broken down.
Finished tail. No more deep scratches.
Finished upper fairing. You can barely tell the way any damage at all on the tank, the dents down the side of the fairing, and the big crack on top.
Finished over all. There are a few small traces of scratches that were really deep, and the headlight is still scratched. Overall I am completely happy with it. I have about $40 in it total!
I have done a few mods to the bike as well before and after I painted it. Most notable is I added a 2005 GSXR 600 steering damper to eliminate head shake. It had some bad spots in the action when I got it, but I flushed out the oil and added the 15w fork oil I had left from draining and refilling the forks to it and worked all the air out. Worked like a charm and I love it! I made some custom brackets to mount it with. I used a piece of flat steel that I cut, bent, drilled and painted black for the upper mount and a piece of aluminum for the fork mount. I will post some pics when I can. I removed the fork tubes and hung them to drain them when I changed to 15w fork oil. I did it right to eliminate any problems taking short cuts would cause. Got rid of the front end diving and really shiffened it up quite a bit. I am mostly satisfied but am wanting some traxxion top adjustable emulators.
Mods as of September 2009:
R6 throttle tube
Yoshi RS3 muffler
aTRE by Steve
PAIR mod
TPS adjustment
De-snorkled
15w front fork oil
Flush mount front blinkers
Custom plate mount
Small rear blinkers
Black windscreen
Whole bike painted satin black
I have several mods that I will be doing in the next couple of weeks. I purchased a 2006 GSXR 600 rear shock on ebay for next to nothing. I am only 165 lbs geared, so this is great for my weight. Plus, not very many things have to be changed for it to bolt up. The only draw back is the spring is yellow, but I can live with that. This will lower the back about 1" to 1 1/2" so I am going to use some shorter dogbones to lift it back up. I am also going to slide the front forks up in the triples a little so over all the whole bike will be about 1" lower, and the front will be slightly lower than the front for faster turn-ins in corners. I also bought a set of new, never installed, but damaged lower fairings on ebay for a steal! One of them has about a 4" crack in the side of it, but other than that they are brand new. I will fiberglass, bondo and paint them using the same process as I did on the bike so they match. I will probably take the upper fairing off and touch up the tiny chips on it too while I'm at it. I am also going to remove the rear grab bar. I am just going to cut it off flush with the rear body work, paint the ends, and put what is left back. That way the rear seat will still latch and the center piece that is left will hide the holes in the sides of the rear section. I'll paint a few things while I have it taken apart like the fork lowers and maybe the rearsets. I plan on redoing my license plate bracket so it's smaller and painting it to match too. I am also going to rework my shifter and make it look better. When it broke in my low side, the peg broke off. I just drilled it and put a bolt through it so it looks kinda bad, so I am going to do something with it so it looks better. There are a few other small things I want to do and will update as I do them. I will try to do a full write-up with pictures on the gsxr 600 shock install. I cannot find one on here so hopefully that will help others out who are doing the same. I will try to do the same for the lower fairings to help those who have never done body work and rattle can painting. I will try to answer any questions anyone has as best I can if you have any. Just PM me or start a new thread. Thanks!
List of up-coming mods as of right now. Sure to add to it.
OEM lower fairings, painted satin black to match
Frame sliders/moto sliders (haven't decided yet)
Rear spool sliders
Up 2 tooth sprocket in the back
GP shifting (might try it a while - 1 up 5 down shifting)
Rear seat cowl
Cut Yoshi RS3 can down to about 12"
50mm high velocity stacks
Traxxion top adjustable emulators
More sure to come.....
