1 - 1 of 1 Posts
Does anyone know if the other year clutch levers or clutch lever assemblies will work on the 2006? The clutch lever broke flush with where its attached to. I took it apart and took out what broke. I assume that the small white tab that moves inside is what signals the bike that the clutch is depressed at that it can start. But even with it in both forward and back positions and the clutch cable manually pulled out it still wont start, Is it possible the switch is messed up also? Although I dont see how it could be. Thanks for your responses.
1 - 1 of 1 Posts
