1 - 20 of 49 Posts
Has anyone come out with a mid-pipe mod that would bring the exhaust can closer to the bike? The Yosh slip-on attaches to the outside of the passenger foot-peg on the 2004 SV650S - not to the inside like the stock can, and thus angles away from the frame. I posted this same question a couple of months ago, and there didn't seem to be a cure at that time.
Thanks,
Tom
Thanks,
Tom
Complain to Yosh until they release a bracket that actually fits a 04-05 bike.
Has anyone installed the new Yosh 04-05 versions? These have different part numbers than the 03 versions.
04-05 SV650 MODEL EXHAUST DESCRIPTION PART# PRICE
04-05 SV650 RS3 RACE SLIP-ON STNLS 1112255 $309.95
04-05 SV650 RS3 RACE SLIP-ON TI 1112257 $379.95
04-05 SV650 RS3 RACE SLIP-ON CARBON 1112252 $419.95
04-05 SV650 TRS RACE SLIP-ON STNLS 1112465 $329.95
04-05 SV650 TRS RACE SLIP-ON TI 1112467 $389.95
04-05 SV650 TRS RACE SLIP-ON CARBON 1112462 $439.95
04-05 SV650 RS3 RACE F/S 2/1 STD MT STNLS 1112055 $619.95
04-05 SV650 RS3 RACE F/S 2/1 STD MT TI 1112057 $639.95
04-05 SV650 RS3 RACE F/S 2/1 STD MT CARBON 1112052 $669.95
04-05 SV650 RS3 RACE F/S 2/1 HIGH MT STNLS 1112056 $619.95
04-05 SV650 RS3 RACE F/S 2/1 HIGH MT TI 1112058 $679.95
04-05 SV650 RS3 RACE F/S 2/1 HIGH MT CARBON 1112053 $719.95
04-05 SV650 TRS RACE F/S 2/1 STD MT STNLS 1112065 $599.95
04-05 SV650 TRS RACE F/S 2/1 STD MT TI 1112067 $665.95
04-05 SV650 TRS RACE F/S 2/1 STD MT CARBON 1112062 $719.95
04-05 SV650 TRS RACE F/S 2/1 HIGH MT STNLS 1112066 $639.95
04-05 SV650 TRS RACE F/S 2/1 HIGH MT TI 1112068 $709.95
04-05 SV650 TRS RACE F/S 2/1 HIGH MT CARBON 1112063 $759.95
i have the same problem with my 05...it kinda sucks...not sure what to do other then just live with it...
For those of you that have the goofy fitting yosh cans any decent welder should be able to fix this in under a half hour and not charge much.
what do they to do fix it?
Pipe sticks out
I have the same problem. I have an 04 SV650S, RS3 pipe, and it sticks out. I've tried playing around with the joints and all that but I can't move it in. Anyone figured it out yet ?
Sergio
flinx said:
Yep, chuck the Yoshi, buy an M4 and no more sticking out!!
Thats what I did! :D
Flinx
no thanks...
Cut a wedge shape out of the aft bend in the midpipe. Pull can to desired location and then tig weld up the midpipe.
Quick short explanation lol. :D
Hmm I have no idea how to weld, but I'll have to get that straightend out asap. Seats were 250$. There's someone in toronto at a shop that has the same bike, but his pipe is on the inside, so I'll have a chat with him, see what the secret is, or maybe he got his welded.
Sergio
Just curious, what's the difference between 03 and 04? I have a RS3 on my 03 naked and didn't have any problems with fit.
Different subframe. Make the position of the passenger pegs different, and hence the bracket isnt quite right.
sent my full 03 header back to yosh...should be getting the new 05 Header back tomorrow for my 2004 Svs. Call yosh and complain.
problem solved
I also has the same problem but I did take it to welder who made two cuts on either side of the pipe down at the header. This made it easier to bend and he welded the cuts back. You can't even notice the cuts and it brought the pipe in about 2 inches and looks much better. I'll have pics for you in the next couple of days
Sergio
ya, keep us informed! :D
Hi guys, I just registered here cause I found this thread AFTER I bought my yosh pipe and discovered the above mentioned fit problem. I bought the pipe from Oneida Suzuki and I seriously doubt that they will accept a return on it.
In any case, the Yosh online store clearly indicates that I have the correct part number for the 2004 sv650s but obviously it does not fit as it should.
I sent an email to yosh tech support last night. I'm hoping they already have a solution. I think all that is needed to make it fit would be a different midpipe.
If anything interesting comes back from Yosh, I will post it.
BTW, where did those "new" 04-05 part numbers come from? I haven't been able to verify them.
Charles
04-05 numbers originally came from Yosh. They are on StarCycle web site as well. Strangely Yosh online store doesn't have them.
1 - 20 of 49 Posts
