1 - 3 of 3 Posts
I pulled out the bike today after it sitting over the winter and when I tried to fire it up it began leaking fuel from the bottom of the carburetors and after I released the start button the bike continued to try starting even after the key was out of the ignition and the only way to stop it was to pull the cables off the battery.Does anyone has an idea of what could be causing the starting problem like that?
57458
Starter relay stuck. Happens most often when the battery is weak. Low battery means more current draw from the starter, which welds the contacts in the relay closed due to heat.
Order a new starter relay and charge your battery in the meantime.
Good chanced the battery is toast also.
Damaged batteries - like ones brought back from the dead after being discharged all winter - are more likely to fry the starter relay than a healthy but simply discharged battery.
The leaking fuel is due to bad needle/valve seats at the carburetor floats. The vacuum petcock at the fuel tank might also be stuck open.
1 - 3 of 3 Posts
