1 - 2 of 2 Posts
A little less than a week ago I went over the handle bars on my sv after being cut off. I froze up and locked up the front tire at 45 sending me into the tarmac head first. Ever since then I cannot get the bike to fire up so that I can at least have some chance of selling it. The bike will crank but will not fire. So its not seized. Is there some kind of switch on the bike causing it not to fire? Like a fuel cut off switch or kill switch?
If it cranks, then all of the "fail safes" are working as they should be. Do the usual tests to verify that you're getting spark in both cylinders and enough fuel in both cylinders. Also, this would be a good time to go over any electrical connections to make sure nothing got knocked loose.
1 - 2 of 2 Posts
