1 - 2 of 2 Posts
Here's a tricky one:
I'm trying to convert a 2001 S to a naked. I plan on using an 2nd gen 2005 stock headlight. The question is, what modifications to the stock S wiring harness do I have to make to wire up the 2nd gen light?
Any help would be appreciated.
If you're using the naked headlight, you shouldn't really NEED to make any changes. Just plug one of the connectors into the headlight bulb. If you want to, you can cut off the other connector, since the S has two (one for each headlight bulb).
...unless there's something different about the 2nd gen headlight that I don't know. I doubt it though.
1 - 2 of 2 Posts
