Finally...an update on my '01 carb rebuilding journey. I decided to use a temporary auxiliary plastic fuel container. I haven't finished with the tank and wanted to eliminate the possibility of crap from the tank causing problems from the beginning. With this setup, the airbox/filter are NOT installed and I've plugged the rear carb vacuum line that normally goes to the tank fuel valve. I got the bike started without much trouble and the rear cylinder appeared to be not firing. Bike would "idle" at about 900 rpm with just the front cylinder firing. Because of this, the bike had only about 1-2 minutes of run time. After checking the spark plug, it was wet with fuel so I assumed it wasn't getting spark. A bit of a few simple changes and tests (new plugs, check coil wiring, compression check yielded 210 psi) and all checked good. I thought I was still chasing a bad cylinder and the last test was with the bike running (still on the front cylinder only), I sprayed hot start (quick start/spray ether) into the rear carb and low and behold, it momentarily fires. I repeated this a few times to confirm it wasn't my imagination. The carb definitely has fuel in the bowl as initially there was fuel leaking from the carb bowl drain screw (forgot to tighten properly on reassembly) and tightening it stopped the leak. I'm ready to remove the carbs and go through the rear one first. I'm hoping that I made a simple mistake and can figure it out. Otherwise, back to complete disassembly and back in the ultrasonic bath. I'm a bit surprised that if the rear carb is putting in too much fuel that the cylinder won't even fire. During reassembly, the float heights were checked and within the 7mm spec so I didn't need to bend the float tang. The rebuild kit (All Balls Racing brand) had the needle and brass seats so these were used as the original brass seats were corroded and the o-rings were damaged (original needles looked ok) . The pilot jets, main jets and needle jets were all cleaned and looked good so I didn't use the ones in the rebuild kit. I also installed new OEM coaster valve diaphragms. Also, a reminder that the bike was running fine before the previous owner let it sit (and sit and sit) for 4+years. He also had few repair tools and practically no mechanical experience and didn't take anything apart or change anything. Any comments/suggestions are appreciated. Sorry for the long-winded update.
