This is how I am with my Honda V4 carbsI have a spare set, but you'd have to rip it from my dead arms to get it.
Sent from my SM-N950U using Tapatalk
I swear to god it doesn't do anything. I've been reading about that unit for years (it's the same part on a GSF600 MK2 Bandit). There are a few people that claim adjusting it is some miracle cure that fixed their bike. A lot of the old guard on those boards with decades of experience with those bikes say it does absolutely nothing. I lean towards nothing--but I never just unplugged it after riding it to see if I could feel the difference. It's easily accessible on that bike from the right side.I removed the sensor from the carburetor before I ultrasonicced it.
Looks easy enough to adjust. Found a good video on YT Thanks Matt
The thing is that you likely did fuck with it if you touched it at all when cleaning your carburetors. If you did any type of dunking in cleaner (not just blowing carb cleaner/compressed air through passages), you likely uninstalled the electrical component. It bolts to the carburetor through two eccentric bores. The pivot alignment of how you put those two small bolts back on that hold it in place will affect voltage read at the closed and WOT positions. It's a very small positional adjustment that wasn't obvious to me the first few times I was looking at it.That's that thingy with wires going to it that everyone said don't fuck with. So I didn't.
No dunking, just blasts of carb cleaner and compressed air. But it seem the consensus is the thingy has no function. Next carb cleaning I'll remove it and use the ultrasonic cleaner.If you did any type of dunking in cleaner
Honda magna 3rd gen had it too. I can't see it doing much except altering ignition timing between closed throttle and full open shown by the manual. Probably emissions and a slight increase in throttle crispness because the ecu /ignition module should control spark mostly.I can't see what a TPS would do on the CV carbs and what it could electronically/physically control ?
As FI systems use sensors and electronics to control fuel flow I can understand that but on cruder and more mechanical Carbs I struggle to see how a TPS could work:/
Also,
Curvy Carb Throttle Position Sensor question. - SV650.org - SV650 & Gladius 650 Forum
Curvy Carb Throttle Position Sensor question. SV Talk, Tuning & Tweakingforums.sv650.org
Skywalker call your office.Wish we could have explanation from engineers
