1 - 13 of 13 Posts
Hello i just bought an sv 650 and i havent gotten the chance of hearing on since i bought it, whats happening is I don't have spark and i do have fuel but it isnt getting spark to the plug, checked the fuses theyre good (replaced just in case) also replaced the spark plugs for new ngk cr8e no luck. It cranks but it doesn't start not even with starting fluid. The thing is that the starter button is broken so im by passing it, will that affect? Also my clutch lever is broken so i dont have a way to press it. It does crank anyways. Will those two things affect in getting it started? Below is a video i would really appreciate if you guys help me out!
Also the bike is with the side stand does this bike has to have without the stand in order for the motorcycle to have spark? TRIED with and without the stand still nothing
Update: spark plug boots give 12.5volts both of them but no spark still
Check to be sure there is 12v at both terminals (+) and (-) on both ignition coils, front and rear.
If the coils have power but still no spark then could be the ignitor unit has failed.
If you are bypassing the ignition switch could also be the 100 ohm security resistor is missing.
Third possibility is the crank position sensor is bad but that is a rare failure.
Discussion Starter #3
Yup coils have 12v but no spark, and im jumping the starter button not the igntion switch. Hopefully it isnt the ignitor Unit, is there a way to check it?
None of the things you listed will stop sparking since motor is turning.
Check if your crank position sensor is plugged in.
There is no easy way to bench test the ignitor. The only way to test it is install it in a working bike, see if you get spark. You could also install a known good ignitor in you bike but that test is less conclusive and potentially risky to the donor unit.
What did the seller say when you bought the bike? Did you get any history?
Discussion Starter #6
Where is the crank position sensor? There isnt any video out there in yt to see and fix :(
While there, check to be sure the crank position sensor coil (Green and White wires) measures between 140 to 230 ohms. Also make sure there is no continuity to ground.
Discussion Starter #11
Inside generator engine cover. Just follow wire coming out of it and see if it is plugged in to harness.
Okay so i was looking into the cdi wires and one was chewed off and it was specifically i guess the igntion one let go ahead a pictures so i put a wire and it started right up!!
1 - 13 of 13 Posts
