1 - 8 of 8 Posts
So, since Pennzoil motorcycle oil is now officially impossible to find around here (used to get it for <$2.00/qt.), I am forced to change brands. My plan is going with Rotella T 15w40, but I'm concerned about the 15w part. It's winter here in virginia and I will typically ride when it is in the low 20's. Any worries about the viscosity on cold mornings?
according to a quick google search the pour point of rotella t 15w40 is going to be somewhere around -35F to -15F so i'd say that unless you're riding in -F numbers you'll be fine. i've used amsoil 20w50 in the cold with no abnormalities
Then Rotella it is. Thanks Andy (and everyone else, but Andy is the professional oil guy).
andyauger said:
Look in the manual. 15W is fine until you get really, really cold.
Do not depend on the pour point as a guide for what will work in an engine. Look in the owner's manual.
don't have one, only have service manual which says to use 10w40, and the pour point is a generally a good assumption, if you have no other info
I say again, pour point is not a good indicator of a good oil viscosity for a particular engine. Always consult the manual, vendor, or a trusted site like this one.
The manual gives the following ranges:
20W-50 oil, 14 F or -10 C to more than 104 F or 40 C
15W-40 or 15W-50 oil, 5 F or -15 C to 104 F or 40 C
10W-40 or 10W-50 oil, -4 F or -20 C to 104 F or 40 C
10W-30 oil, -4 F or -20 C to 86 F or 30 C
The coldest temperature on record where I live is 8 F, so 15W-40 will work for me all year long. Of special interest is the upper limit on 30W oils.
Remember, (example) 15W-40 means the oil acts like a 15W at 0 deg. C and like a 40W oil at 100 deg. C.
1 - 8 of 8 Posts
