1 - 20 of 29 Posts
with 119,790 miles on th clock, I had my 120 k service done today
as usual, it's still running great, oil consumption is now regular, I have to add about ¼ quart every tank of gas
they put cr7e plugs in due to the now noticable oil consumption
valves were loose by quite a bit
everything else was normal
my mechanic is recommending some time this winter I let them have the bike for a week, for a teardown, something I will have to think very hard about, it just runs too good to think it's at that point
thejimdaddy said:
me too, randy is the high mileage king
naw, I hear rumors of a SV in England that is riden by currier with somewhere in the 150k-160k area
and I've met a BMW rider that has over 700k on a bike that he bought new in the early 70s
Randy,
How come ya never ran synthetic oil? Considering how quick you rack up miles it would seem to make more sense - fewer changes and less wear.
Depends on how much they want for a teardown. If they have reason to believe there is a problem, then it may be necessary. A 1/4 of quart per tank full seems like a lot. Then again, as long as you are keeping up with adding oil, shouldn't be a problem.
crossing the floating bridge on Rt65 in Brookfield, VT
i still dont understand where you get all the time... in both mileage and post count, truely impressive on both counts
Well for teardown I wouldnt think they would really need to do a hole lot. New pistons and rings, bore the cylinders to match new pistons, probabley 1mm larger then stock, then I suppost maybe new valves and springs, new shims to get correct valve lash. Thats all I would do, but I suppose it wouldnt hure to put new bearings in the bottom end, but as far as that goes if it aint broke dont fix it, the top end work I mentioned wouldnt hurt though, would save you some oil that way.
Discussion Starter · #13 ·
yup, that's all they were really taking about was pistons & rings
the oil consumption is more annoying than costly, it doesn't smoke when running except when I really get on it, then not always, I think it's more valve seals than rings. is smoke on startup sometimes too.
Nice to see that a well maintained machine can last a while. Bravo.
"what is a floating bridge?"
At least in the Seattle/WA/PNW area, they are concrete pontoons that are anchored to the riverbed or lakebed underneath and happen to have a roadway on the top of them. Big ones here are I-90 floating bridge, 6 or 7 lanes wide, HWY 520 floating bridge with 4 lanes. Those are in Seattle. Also bridge from SW tip of WA over mouth of the Columbia River to Astoria, OR. That may be close to a mile long. If you search for Seattle Traffic Cameras, you can see various pictures of them, I am sure.
Bad storm on Thanksgiving several years back broke a section of I-90 loose and it floated down lake a bit.
Maybe you've seen the PNW's other famous bridge over the Tacoma Narrows? Called Galloping Gertie in years past, it is the famous shot of a suspension bridge going all wrong in the wind and a dude running from his car trying to get off.
Volcanoes, too...
Discussion Starter · #19 ·
when I get home tonite, I'll see if I can post another pic of the bridge, this is a wooden floating bridge with about a 200±ft span, each end floads just below the surface, when a car drives across, the bridge sinks to about 8-10 inches below the water surface
Rt 65 is a gravel state highway
1 - 20 of 29 Posts
