2006 SV1000S
New owner to my SV1000 so I thought I'd pull her apart a bit and see what gremlins are lying underneath. I've got as far as the flywheel and found the magnets in somewhat of a bad shape.
I was hoping to see what the general consensus is here about whether I JB Weld them back in and run her or if I should try and sort something else out.
My initial thoughts are I don't have anything readily available so I might as well JB Weld what I do have remaining and check how the charge voltage behaves over the next little while?
Looking forward to everyone's thoughts on this.
Wheel Tire Automotive tire Motor vehicle Alloy wheel
Automotive tire Camera lens Cameras & optics Circle Lens
Wheel Automotive tire Motor vehicle Alloy wheel Gear
Automotive tire Motor vehicle Automotive lighting Wheel Automotive design
bummer dude, when mine did thie the first time... i glued them back in, checked it 3000 miles later at oil change time and they were crumbled.. then i bought a new oem flywheel and replaced it. gonna check it again this winter as now i need some clutch work.. its endless with this bike...... good luck with yours!
Hey Adam,
Unfortunately im in the same boat here in Brisbane. 2 magnets are smashed so my bike has been out of action for the last 3 months.
Im not having much luck with any used flywheels or just magnets as they get picked up from wreckers pretty quick and ebay are rare and expensive.
Suzuki AU has one in the country but it will set you back $600, which imo is extortion for a known fault with the model and they still havent recticifed the issue with the new part.
2006 SV1000S
Hey Adam,
I've just bit the bullet and ordered a new flywheel. This bike was meant to be my primary mode of transport (wife has the car) and need it running. I'll most likely have a couple magnets (3x 100% & 1x 95%) up for sale in the near future.
Mine was a tad more than that from a local dealer, but was the cheapest I could get calling around. Don't want to know what it could of been.
Ah nice, I rarely ride the bike so I wasnt in a rush to get it fixed.
If you havent already then you will still need to epoxy the gaps so the magnets dont come loose again.
I would definately interested in getting the 100% magnets off you when you sell them.
