Hey guys,
Weather has been a bit colder here as the the past couple of days and I've been having some trouble with cold starting. I recently installed Steve's aTRE and sync'd my throttle bodies and when warm the bike is completely flawless but with cold starting it idles very low, spits and sputters, and makes random pops from the intake box and it will do this even with throttle applied until it's pretty warm.
TBs sync'd
aTRE installed
TPS adjusted at 1500rpm
Here is a video of the symptoms I'm having and the bike isn't even completely cold. The temp gauge is showing ~80* and it is still having this problem that it has never had. The popping noise you told hear in the video is from the intake box. The colder it is outside the worse the symptoms.
Any help is appreciated!
Tore the bike apart today, weird find. The throttle body had completely come loose from and popped out of its coupler on the rear cylinder and I had a bad battery. I'm pretty sure this will fix my problem but I just thought I'd let SVR know. Thanks for the help!
