OK,
I'm at work. I was just about to go to lunch and discovered the bike won't start. Here's the symptoms: I put the key in the ignition and turn it to the ON position, the electrical turns on fine (lights turn on, clock is on...etc). I turn the fuel pump on; you can hear it turning on as usual. Next I pull the clutch in and push the starter button; but the engine will not fire up. All I hear is the starter spinning. I have no tools with me, which sucks. What could the problem be? Perhaps a spark plug or fuse?
I think this problem may be related to an small incident this morning: I was at a traffic light and i THOUGHT i popped the bike into neutral (green nuetral light was on but it lied!) and i stalled it. Just then, the light turned green so i had to get the bike going fast. I think I started the bike before the fuel pump completely turned on. I think this is the cause of my starter problem. Any help is appreciated asap, thanks.
