So I accomplished a few things and got hung up on others...here's what I have so far (disregard the caliper bracket not on the bike)
Here is the tank bracket that needed some massaging, that bent piece at the bottom was shortened and tweaked a bit. Welded, then painted to cover the welds.
The battery is in, not very pretty, but it fits under the seat (barely).
Rear shock and my modded modified battery box, more like a battery bench now.
So my next issue that needs tackling is shaving down my Vapor speed sensor bracket. Atm the speed sensor is rubbing against the rotor screws. That should be easy enough to do.
Now the real issue mostly because I don't know what size sprocket I have up front, and I didn't even think about having to get a new chain.:facepalm: Anyways, the stock sv sprocket has 45 teeth, the gsxr sprocket that came with my wheel has 48. So the stock chain on the bike is to short, and I know the gearing will be different.
