Could be the ignition switch connector aka Dreaded Green Connector. With the key in the On position, try move the handlebars back-and-forth a few times, see if power comes on.
Discussion Starter #3
Ok so my 07 sv650s suddenly has no( key power) meaning i have good battery but no power to dash with key. Could be a hand full of things. What about converting to keyless switch ignition? Is there a kit to buy? Is it something i should do? Ect. Ect. Ect. Plz help i must ride
Why not check the handful of things and potentially fix it properly? A modification should be something you choose to do to make your experience better, not one you choose to avoid or cover up a problem.
Jonley, I merged your two threads to make it easier to follow.
Did moving the handlebars cause power to come back, even momentarily?
When you checked the fuses did you also check the Main fuse (30A green) located at the starter relay? It is easy to miss as it is not located in the main fusebox.
