Suave's GSXR Swap Pictoral Guide. - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 12-17-2008, 12:00 AM   #1
SuaveNotion
Senior Member
SuaveNotion's Avatar
Bikes: Birthday Suit 2k
Miles Kms: As we speak
So I'm going to make a step by step picture catalog/guide on doing a GSXR swap for a 99-02 SV650. Things should start to come up very soon. I will begin to post as soon as I have the stock front end off. Suscribe if you would like to see it as it goes...
SuaveNotion is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-17-2008, 08:24 AM   #2
SuaveNotion
Senior Member
Re: Suave's GSXR Swap Pictoral Guide.
First you gotta go and get yourself a 99-02 SV650 and get it into your workspace..
Since my garage door doesnt shut and it is currently 1 degree here in WI mine just happens to double as my living room.
Now before I go on I strongly suggest you invest in some baggies and a permanent marker so that you can label things as you take them apart.
The parts list is as follows...
2006/07 GSXR 750 front forks.
2006 GSXR wheel and calipers.
1997 SRAD 750 upper/lower triples.
TWF top bearing kit.
lots and lots of fasteners...
So start by getting the bike up with a rear jackstand and secured in the front with a regular jack but don't jack it up yet. You'll need to do a lot of torquing on some nuts, especially the ones for the handlebars and the bike isnt very stable once it's been lifted.
So start by undoing the headlight bolts, 2 on each side and a third on the bottom.
For some reason i dont have a pic of this, but its pretty self explanatory.
Then undo the controls, the left has 2 and the right has 3 screws.
There are also 2 screws to remove the left mirror along with the master cylinder. They come out with an 8mm socket. The right one will have to be slid off after the grip is removed.
Ok so now its time to get the handlebars off...
The 4 chrome things on top of the risers can be removed using a razor blade but be careful not to scratch them.
This bolt sucks...you really need a lot of leverage to get it off so its a good idea to like slide a pipe on the end of the wrench. This is the bolt that holds the lower part of the riser in place.
After you get that off the triple should look something like this...
The next thing is to remove the gauges which you can also see in the above pic. All it takes is some more finesse..It has 2 bolts that are located ahead of the 2 that keep the risers on.
Lookin good...So now you gotta take off the top nut. Be careful not to lose the washer that is under it. Also, you will need an allen wrench to remove the upper pinch bolts.
After that it slides right off.
Makes you wonder why people on ebay always say "damage from where triples clamp". If I can do this without damaging it, anyone should be able to.
And the bottom of the triple clamp. In this pic the upper holes are for the speedo and the lower ones are for the risers.
Ok now you can jack the bike up. I would suggest only getting it off the ground far enough so that the tire can clear the ground. It's also a good idea to put jackstands under the pegs for added stability.
The wheel comes off relatively easy. Just unscrew the axle and it comes out as a whole. Watch for the speedo sensor on the left side, it's crammed in between the fork and the wheel on the left side. Also, you will have to remove at least one of the calipers for clearance.
So this is kinda what it will look like:
Old 12-17-2008, 08:25 AM   #3
SuaveNotion
Senior Member
I'll continue to post as I take parts off...
Old 12-17-2008, 08:33 AM   #4
Jan Zoellner
Senior Member
Bikes: SV 650 S
Miles Kms: 80.000
This is gonna be interesting. The SRAD triples are wider than later makes, making alignment of the rotors and radial calipers a bit tricky with the (slimmer) wheels from 00 up. What are you gonna do about that? What axle will you use?
Looking forward to your further progess!
Ciao
Jan, SRAD triples, SRAD wheel, SRAD axle, 04 rest => shimmed rotors
Jan Zoellner is offline   Reply With Quote
Old 12-17-2008, 09:51 AM   #5
redmonkey
Senior Member
redmonkey's Avatar
Bikes: SV'99 at the mo I don't know
Miles Kms: about 76xxx kms
Send a message via MSN to redmonkey
Ciao
+1 shimming will be required i run srad triples and axle with busa rim and 05 gsxr 600 forks, you need a 2 to 2.5 mm shim between the rim and rotors for the calipers to line up correctly
__________________
My Twins keep trying to kill me.
redmonkey is offline   Reply With Quote
Old 12-17-2008, 10:52 AM   #6
Jan Zoellner
Senior Member
Bikes: SV 650 S
Miles Kms: 80.000
Quote:
Furthermore hell need a way to center the wheel - its a tad slimmer than the wheels we use. Im curious what he comes up with, especially since I know very little about the changed axle design from 06 up...
Ciao
Jan
Old 12-17-2008, 02:40 PM   #7
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
Those appear to be 600 forks I think? Haven't seen any gold 750 ones, they are usually black on the 750?
You will also need shims between those fork legs & lower triple clamp - the SRAD is for 54mm legs, those Showa 06+ forks are 53mm. So you will need some 0.5mm (~20thou) shim material to make a sleeve.
It will indeed need the 3.5mm rotor shims (2.5mm for a TL/busa wheel) and the wheel will also need to be offset by 3.5mm on the axle. Stock spacer on right side of axle is 12.25mm - should be 14.75mm to recenter wheel.
So can make a new one-piece spacer or add 3.5mm shim stack between right spacer & right fork leg.
An 08 Hyabusa axle will account for the extra width required (forkspacing will be 7mm wider using those SRAD triples)
D'Ecosse is offline   Reply With Quote
Old 12-17-2008, 03:37 PM   #8
redmonkey
Senior Member
redmonkey's Avatar
i believe those are 04/05 600/750 forks but the glare might be throwing me off a bit
__________________
Old 12-17-2008, 04:08 PM   #9
D'Ecosse
Titanium Member
D'Ecosse's Avatar
i believe those are 04/05 600/750 forks ...
Later Axle tells they are definitely the 06+ forks - gold are more likely the 600's however.
In fact the fiche does not show an alternative colour so have to be the 600's.
I see on EBay all the time they are listed by sellers as 600/750 - they are the same fitment however, but the 750's (black outer tubes) have stiffer springs (1kg vs 0.9) - dampers are identical.
Old 12-17-2008, 04:32 PM   #10
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Everyone has their own way of doing things so this isn't criticism just alternative:
After removing the riser tops & bars, drop the speedo, then undo the top clamp & flip it over & stick it back on the forks to get easier access to the riser nuts & ignition bolts (unplug ignition harness if it helps to get extra freedom)
No need to re-clamp it up, just use the forks to hold it from turning.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Where is the step-by-step gsxr swap pictoral guide? does it exist? vilago SVRider Motorcycling Forum 34 04-01-2011 10:51 AM
Suspension set up guide - what are good starting measurements / how-to guide? superwormy Racing Discussions 3 11-05-2010 09:08 AM
Suave's GSXR Swap Post SuaveNotion SVRider Motorcycling Forum 7 12-17-2008 11:58 AM
any pictoral how-tos on cutting down a factory exhaust can? wallymann SV650 Gen2 (03-15) Tech 7 11-14-2007 09:58 PM
My completed guide for gsxr front end swap gunluvS14 SV1000 (03-07) Tech 1 01-17-2006 04:41 PM
1999-2009 SVRIDER.com.
