cold running issues - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 11-07-2019, 07:43 PM   #1
tonusmaximus
Junior Member
Bikes: 2005 sv650
Miles Kms: 4000
cold running issues
05 naked w 4k miles and needing some help here....
the bike starts easy but wont idle and runs crappy until the bike warms up then pull hard and runs great and idles right at 1250 after I blip the throttle long enough to get it completely warmed up. not neccessarily just when temp guage shows 180 or so degrees but physically the engine or an electrical part because i can shut it off and start it again in a couple mins and it runs like crap again and has at least 150 degrees showing
the coils are showing 6 ohm between the 2 legs and 27k between positive and sparky cap. 2 -5ohm according to manual and the secondary is 24-37k
It doesn't have a programer also.
could this be a fuel issue? PO had a new fuel pump put in for some reason and it does prime for about 5 or so secs when I turn the key. Just seems like somethings warming up and making contact
tonusmaximus is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-07-2019, 07:48 PM   #2
tonusmaximus
Junior Member
Bikes: 2005 sv650
Miles Kms: 4000
Re: cold running issues
also the front spark plug when I held it to the chassis was yellow and not as strong as rear. new ngk's I gapped and put in myself
Old 11-12-2019, 01:59 AM   #3
sv650bklyn
Senior Member
Bikes: 2006 SV650 (Gen 2)
Miles Kms: 53000 mi
To fix your crappy cold starts, I'd do a Fast Idle Adjustment (section 5-32 in the service manual). It mainly consist of setting the TP sensor output voltage to exactly 1.21 V. I bet yours is way off.
Once that's done I'd check all the following, firstly the vaccum hoses (work your way up from the bottom of the list):
__________________
Build thread | Instagram @sv650nyc
sv650bklyn is offline   Reply With Quote
Old 11-12-2019, 03:16 AM   #4
Craig380
Senior Member
Bikes: Blue 650 AL7, replaced my K6S (RIP)
Miles Kms: New bike: 1,610 and rising. K6S had 21,380 until it was killed by a patch of diesel
The fast idle system for cold starts works off the STV actuator, it pushes a cam which opens the throttle a little. It's entirely triggered by coolant temp, so it sounds like yours is off.
First, I would tweak up your hot idle speed a fraction to 1300 - 1350rpm, 1250 is a hair low. Then don't mess around with measuring voltages etc for the fast idle setting, just tweak the fast idle screw a tiny bit clockwise. You'll need an angled screwdriver or a right-angle driver.
In sub-50F temps, I found my K6 SVS was stumbling and chugging from a stone-cold start in the morning, and would need a little blip on the throttle to get it firing evenly. It would then idle smoothly at around 1600 - 1700rpm (hot idle was 1300rpm).
I gave the fast idle screw a tiny adjustment clockwise - I mean literally no more than 1/12th of a turn - and it sorted it completely. In the same ambient temps, the engine now bursts into life immediately with no stumble or chug, and idles at 2200rpm for about 5 seconds, then gradually dials down as it warms up. No need to massage the throttle.
So tweak the screw gently - even 1/8th of a turn may be plenty. The adjustment is very sensitive.
Craig380 is offline   Reply With Quote
Old 11-13-2019, 07:44 AM   #5
tonusmaximus
Junior Member
Bikes: 2005 sv650
Miles Kms: 4000
Thank u both for chiming in.... I installed 2 known good coils and crappy cold start/running situation remains unchanged. Set the TPS to go to top at about 1450. still no change.
I'll look into the advice provided and check for vacuum leaks and look at ballalncing the throttle bodies. Bike has some specs of rust in tank and PO installed a fuel pump. I'll have to check the flow coming out of it also I guess. Possible the injectors clogged?
Old 11-13-2019, 07:47 AM   #6
tonusmaximus
Junior Member
Bikes: 2005 sv650
Miles Kms: 4000
Also want to add that when the bike does fire up it doesn't high idle when I get off the throttle but goes to the Hot idle setting rpm's
Old 11-13-2019, 07:48 AM   #7
tonusmaximus
Junior Member
Bikes: 2005 sv650
Miles Kms: 4000
I made a dealer tool and set the tps to go top of dash as per manual.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
