Cam Swap Timing Question - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > Racing
Racing **POTENTIAL SPOILERS INSIDE** Discuss racing SV's - or talk about your favorite racers, from MotoGP to the local club circuit.
Reply
Thread Tools Display Modes
Old 10-16-2019, 11:46 PM   #1
busdriver
Member
I had to pull the engine apart to fix a shelled out transmission. Then I got to doing a bunch of nerdy math to see if I could figure out how jacked up the cam timing would get if I decked the cylinders to get the compression bumped up a bit, and would I really need adjustable sprockets.
To get to the point: Counting teeth, I'm getting a 140 degree shift when moving the intake over to the exhaust (14 teeth total, or 6 teeth left of the 1f to draw a 2). So if the APE site's cam specs are accurate (33 BTDC, 66 ABDC, 279 dur) then I'm getting a lobe center of 113.5 on the 2nd gen intake on the exhaust side. That seems like a wonky number.
What am I missing?
Side note: If I'm thinking about this correctly, the cam timing will go in opposite directions when decking cylinders/milling heads since the cam tensioners are on opposite sides of the motor.
busdriver is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-18-2019, 03:19 AM   #2
RecoilRob
Senior Member
Bikes: '07 SV1000S
Miles Kms: 43379
Re: Cam Swap Timing Question
It doesn't matter where the chain tensioners are...taking material off of the cylinder puts the cams closer to the crank so their timing will be advanced.
Picture holding the cam and assume that it is in perfect timing with the crank...then slowly drop the cam down rolling along the chain...it moves forward so without moving the crank the cam is now advancing. Advancing the intake timing means the valves will close sooner which can boost effective compression and often will boost the midrange torque, and if you don't go overboard with it the top end power shouldn't be affected. But this will depend on the exhaust system tuning so be aware that ANY changes will affect the system and be prepared to alter other things to compensate.
RecoilRob is offline   Reply With Quote
Old 10-18-2019, 02:49 PM   #3
tovar
Senior Member
tovar's Avatar
Bikes: mali tovar
Timing gets retarded
tovar is offline   Reply With Quote
Old 10-18-2019, 02:59 PM   #4
swiest152
Senior Member
swiest152's Avatar
Bikes: racebikes
i think its something like every .010 off head is .5 degrees on cam.
__________________
CCS/ASRA #60 | TWF Racing | LWT Racer | Titanium for SV650
Quote:
Originally Posted by tovar View Post
there is no school that will make you fast if you don't have it in your self. Talent can not be learned.
swiest152 is offline   Reply With Quote
Old 10-18-2019, 03:19 PM   #5
tovar
Senior Member
tovar's Avatar
Bikes: mali tovar
Something like that, closer to 1 degree for 10 thou.
Old 10-18-2019, 03:44 PM   #6
RecoilRob
Senior Member
Bikes: '07 SV1000S
Miles Kms: 43379
Yes...you are right. ( It was really early...shouldn't try to think before lunch). The tensioner WILL determine what happens...it's on the slack side while the other side pulls, so shortening the drive side will retard it. Sorry....
Old 10-18-2019, 05:31 PM   #7
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
One degree cam timing change is roughly = pi * cam sprocket dia /360.
If cam sprocket diameter is 2.5" then 1 deg = 0.022".
The angle the cam chain makes with the head has some affect but is small enough to ignore.
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Old 10-18-2019, 05:37 PM   #8
tovar
Senior Member
tovar's Avatar
Bikes: mali tovar
Quote:
Originally Posted by TeeRiver View Post
One degree cam timing change is roughly pi * cam sprocket dia /360.
That formula includes 2 crank rotations per one cam rotation?
Like cam has 36 teeth but each one is 20.
Old 10-18-2019, 05:49 PM   #9
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
That is degrees of cam rotation relative to milling the head.
Two degrees crank rotation per one degree for the cam.
One degree of crank rotation would be 0.011".
__________________
Old 10-18-2019, 07:43 PM   #10
tovar
Senior Member
tovar's Avatar
Bikes: mali tovar
So 10 thou is about 1 since crank rotation is measured.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
