Clutch adjustment - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 08-08-2019, 07:49 PM   #1
RIDER675
Senior Member
Bikes: 07 track, 99 street
Clutch adjustment
Ive posted about this same problem before I think? Suspect somethings up with my clutch because I cant adjust it properly. Which way do I turn the mechanism to make it easier to shift? Clockwise I thought? Think ive tried every possible position on the damn thing today, from out none to about 1/2 turn. Only one very specific position seems to work but I had trouble downshifting. Supposed to be loaded up for a trackday atm
RIDER675 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-09-2019, 12:03 AM   #2
RIDER675
Senior Member
Re: Clutch adjustment
Somethings not right, while the adjustment isnt random there isn't a trend going one direction or the other. Adjustments are repeatable only just, because its sensitive to 1mm adjustments. Going to rebuild the worm gear tomorrow in case its put together wrong. When the clutch is starting to engage I can hear it knocking, is this a sign of anything?
Old 08-09-2019, 05:58 AM   #3
Straticus
Senior Member
Straticus's Avatar
Bikes: 1999 X naked Curvy
Miles Kms: 24,000
I went through this when I got my Curvy and made a page of the work I did,
https://cx500.000webhostapp.com/SV650ClutchLifter.html
as I had trouble getting into neutral.I tried a new,"Slinky Glide" cable which I had used on other bikes but the Metal curved guide had a tighter radius and bound causing the lever to be stiff.Went back the the original,no problems.
__________________
https://www.youtube.com/watch?time_c...&v=xmOo_AhyJJU
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails."
Straticus is offline   Reply With Quote
Old 08-09-2019, 10:48 AM   #4
RIDER675
Senior Member
Good info, I switched to a race cable without metal bends because the originals would split after a few days. Depending how it's adjusted it can shift, but the pull is ridiculously heavy. If I leave 3mm play at the lever for instance, but if I set free play to 4-5mm the bike creeps forward in gear, no matter how its adjusted.
Made sure the worm gear was together properly already, your page was very helpful also for my other sv. Guess ill try the original cable.
Old 08-09-2019, 03:31 PM   #5
RIDER675
Senior Member
Suspect an internal clutch issue, also hearing knocking as I let the clutch out. Any idea where to start?
Old 08-09-2019, 04:23 PM   #6
nicks-sv
Member
Bikes: 2002 sv 650N-2007Yamaha 1100
Miles Kms: 2,500
mine has a low clunk when i let the clutch out in neutral
nicks-sv is offline   Reply With Quote
Old 08-09-2019, 06:30 PM   #7
RIDER675
Senior Member
Quote:
It's a rhythmic hollow knock that slows as the clutch is let out in gear.
Old 08-09-2019, 07:54 PM   #8
nicks-sv
Member
Miles Kms: 2,500
i can only hear it in neutral, i pull the clutch in and it goes away. low rythmic clunk or muffled knock. like the previous owner revved it up and dumped the clutch. maybe the clutch basket got twisted.
Old 08-10-2019, 12:12 AM   #9
jksh25
Junior Member
I would do a visual inspection of the clutch basket. It only takes 20 minutes. Remove the clutch cover. Do a quick check of clutch bolt tightness.
Then remove the stack of friction and slick plates (keeping them in order slick/friction/slick/friction/etc) and pay attention to 1) discoloration (overheating), 2) warped discs, 3) smoothness of slots and teeth of basket and discs, and 4) no damage to springs or pressure plate.
jksh25 is offline   Reply With Quote
Old 08-10-2019, 02:54 PM   #10
RecoilRob
Senior Member
Bikes: '07 SV1000S
Miles Kms: 43379
Think about what you are trying to accomplish when adjusting the clutch: you need enough free play to allow the springs to compress the plates without any pressure loss to the disengagement mechanism.....while allowing the clutch lever to disengage the plates far enough so they don't drag. The easiest way to go about it is to just make sure you have a little free play when the lever is fully released (both at the clutch release mechanism as well as the lever itself) and then whatever pressure it takes to pull the lever is all in the clutch springs with the added drag (which should be minimal) of the cable friction.
If it's difficult to shift that sounds like the clutch isn't disengaging......which could either be improper adjustment or something mechanical internally preventing the clean release of the plates. Once you have the free play at the worm drive adjusted so it's adequate to ensure full engagement...but only a wee bit so the clutch lever movement can press the plates apart as far as possible....if it still drags then you have an internal problem.
RecoilRob is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©1999-2009 SVRIDER.com.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
