Changing oil filter every 3k? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 05-11-2019, 08:57 AM   #1
F9zSlavik
Site Supporter
Bikes: Suzuki SFV650
Would you guys change the oil filter with every oil change if dine every 3k? Maybe I mis read but someone had suggested that at 3k it's not worth changing and was hoping if someone could clarify.
F9zSlavik is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-11-2019, 09:46 AM   #2
rcb78
Member
Bikes: 2017 SV650, 2013 F800GS
Re: Changing oil filter every 3k?
Don't know about Gen2, but for Gen3 the service manual says to do the filter every other oil change. Then again there's no harm is doing it more frequently, just a little added expense.
rcb78 is offline   Reply With Quote
Old 05-11-2019, 01:20 PM   #3
golden chicken
Senior Member
golden chicken's Avatar
Bikes: 2005 SV650n
Miles Kms: 58,000
I personally do an oil filter and oil at 3000 miles.
__________________
Have a nice ride.
golden chicken is offline   Reply With Quote
Old 05-11-2019, 02:49 PM   #4
Craig380
Senior Member
Bikes: Blue 650 AL7, replaced my K6S (RIP)
Miles Kms: New bike: 1,610 and rising. K6S had 21,380 until it was killed by a patch of diesel
For the Gen 2 bikes (K3 onward), Suzuki's service schedule is an oil change every 6,000km / 3,750 miles, with a filter change every 3rd oil change (i.e. every 18,000km / 11,250 miles).
Some people change the filter with every oil change, some people change the filter every second oil change, some people follow Suzuki's schedule. The choice is yours.
Craig380 is offline   Reply With Quote
Old 05-12-2019, 11:38 PM   #5
SD 650S
Senior Member
SD 650S's Avatar
Bikes: SV650S
I recommend you change it at every oil change.
Mainly because half a quart of old oil will stay in your bike if you don't change it.
Why go through the effort and expense of a oil change and leave half a quart of dirty old oil in your bike? Spend the extra $5-$10 and change your filter.
SD 650S is offline   Reply With Quote
Old 05-13-2019, 10:09 AM   #6
twag4
Supporting Member
Bikes: 01 650s
Miles Kms: 22000
I don’t understand Suzuki advising to change filter every other change. Clutch debris alone is reason enough to change the filter. For under $10, I change mine every time.
twag4 is offline   Reply With Quote
Old 05-13-2019, 01:33 PM   #7
SkyHighJK
Member
Bikes: 2006 Nekked & Red
Miles Kms: 3-29-2019 -- 14,500 total / 3,000 of them mine.
I think there's some argument where an oil filter actually filters better as it ages (up to a certain point, of course) so that a fresh filter with each oil change can allow some small particles to float around for a while.
Imagine, like, cheesecloth vs a screen door. A screen door can still let through quite a bit of tiny particles, but as it gets clogged up it might resemble something closer to cheesecloth, which should filter better. (This is a pretty crappy anology, I know!) As long as full oil pressure can still be maintained, cheesecloth is better than a screen door. At least -- that's the argument/theory.
-JK
SkyHighJK is offline   Reply With Quote
Old 05-13-2019, 07:37 PM   #8
twag4
Supporting Member
Bikes: 01 650s
Miles Kms: 22000
The problem is that when there is too much trash, the filter will bypass. Now zero filtering occurs. The new filter media will not let very big particles through at all- especially top of the line filters with good media. Modern oils, especially synthetic, are exceptional at keeping particulates in suspension rather than depositing them inside the engine.
-JK
Old 05-13-2019, 08:14 PM   #9
OfirMX
MOTORADOR
OfirMX's Avatar
Bikes: 2006 DL1000, 2004 SV650, 2000 SV650, 2007 GSF1250 & GSX-R750
Miles Kms: ∆
Quote:
Originally Posted by twag4 View Post
I dont understand Suzuki advising to change filter every other change. Clutch debris alone is reason enough to change the filter. For under $10, I change mine every time.
Maybe it has to do with them knowing a thing or two about their engines
Sent from my SM-G970U using Tapatalk
__________________
Proper motorcycle training is like wearing a helmet. You can ride for 30 years without one and make a case that you've never needed it. Until you do but then it's too late to make that decision.
OfirMX is offline   Reply With Quote
Old 05-13-2019, 09:16 PM   #10
rcb78
Member
Just a hypothesis, but tell me if this makes sense... Plenty of car filters out there that are just as small as ours. They currently spec 6k-10k miles between oil/filter changes, so the media itself should be good for that long if the engine is in good shape.
I suspect we actually change our oil sooner simply because of the higher operating rpm range combined with the acceleration rate of our engines. This can lead to shearing of the oil and consumption of the additives due to mechanical breakdown of the polymer chains. So the 'short' oil change interval is more about replenishing the oil properties than it is about removing contamination and filter itself should still have life in it.
Just an idea... but yeah, oil filters are cheap so why not?
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oil filter change every other oil change. Sandro SVRider Motorcycling Forum 36 03-13-2019 10:30 AM
changing oil filter but not oil? Jloveridge1994 SV650 Gen2 (03-15) Tech 24 07-24-2015 10:15 PM
Why is it recommended to change the oil every 3k? Med!c SV Modifications and General Maintenance 26 11-02-2010 11:52 AM
changing to .95 springs without changing the oil jcamel SV Modifications and General Maintenance 27 12-10-2009 10:02 PM
Anything to do before changing oil, oil filter PAB SVRider Motorcycling Forum 11 06-06-2008 03:59 PM
1999-2009 SVRIDER.com.
