New User? Register - Forgot Password |
Register | Forums | FAQ | Gallery | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Motorcycle Escrow | Insurance | Advertise |
The Build Board A place to post a journal or log of your SV / Gladius projects and builds. No replies or discussion are allowed. |
Thread Tools | Display Modes |
#1 |
Greetings Program
![]() Join Date: Jun 2013
Bikes: '06 SV650N
Miles Kms: >60k
Dory - a blue K6 Naked.
This thread will be slow moving after the start, as it will consist mainly of maintenance. I'm fairly happy with the nearly stock appearance, and don't have major modifications planned in that arena. This is as much to document the condition, care and feeding of my bike.
As purchased, it had CRG LS mirrors mounted, and was missing the gauge pod cowls. The previous owner had dropped it, scratching his preferred mirrors (a set of Napolean bar end mirrors) and one side cowl piece. ![]() It came with a Two Brothers M2 Carbon exhaust, SV gel seat, an unknown fender delete kit, stubby aluminum front signals and LED cheapo rear signals. ![]() A replacement right front cowl section was on order at the time I purchased the bike. I re-installed the Napoleon mirrors, as I felt I could see much better with them than the CRG's. I also installed the cowl and flyscreen as soon s it arrived. The left side included a hole for the heated grip switch. ![]() I also picked up a pair of saddle bags and a small tank bag off CraigsList, so that I could carry groceries home. ![]() I then added new Metzler Sportec M3 tires, blue reflective wheel tape, Motosliders, and HammerGrips. ![]() To date, the only other changes are:
Upcoming modifications will be mostly performant:
Updates will follow as changes are made.
__________________
Dory - a blue K6 Naked, lives again. Build thread and Comment thread - also The SV Colors Compendium
Sponsored Links | |||
Advertisement
#2 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Re: Dory - a blue K6 Naked.
__________________
#3 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Namesake:
__________________
#4 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Nearly complete record of ownership so far
2006 Suzuki SV650 Purchased on 6/3/2013 Miles: 6650 (6500 when I started riding it) Included: * Bike * Heated Grips * Two Brothers racing M2 V.A.L.E. exhaust * Stock Mirrors * 2 sets aftermarket mirrors * Extra, original stock seat * Original stock grab bar * SRAD lowering links * Extra front turn signal * Scratched right front cowl * Rear work stand * Dunlop D220 Sport Turing tires I added: * 12v socket * small saddlebags * tank bag * Throttle palm rest (cruise helper - "Cramp Buster") 6/10/2013 At 6860 miles: * Muffler repacked with new fiberglass material 6/13/2013 7010 miles * Added P1R tip and spark arrester to muffler. 6/27/13 7691 miles: * oil and filter with Mobil 1 15w50, chrome H&R oil filter * added RAM Mount for cell phone. 7/6/2013 8144 miles: * New tires: Metzler Sportec M3, 160/60ZR17, 120/60ZR17, $339.89 after taxes * Cleaned, lubed and checked chain 7/16/2013 * Installed MotoSliders frame protectors 7/19/2013 * Added reflective blue rim tape 8/9/2013 * Added 3M film to rear body, and spots on tank. 8/19/2013 10520 miles: * oil change with Mobil 1 15w50. * oil sample taken to be mailed to Blackstone Labs. 8/27/2013 10657 miles: * Added HammerGrips tank grips. * Removed most of the bar mount for phone until later. 8/28/2013 10657 miles: * Installed 434Racer adjustable brake and clutch levers, black with blue adjusters. * Received Tailbag.
__________________
#5 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
I was able to find an '08 GSXR 750 shock on Ebay cheap.
![]() Next step is to get the shock installed.
__________________
#6 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Shock is installed. It did drop the rear a little, so now I'm trying to decide if it's OK as is, should I drop the front a little, or should I get new dogbones made to bring it back up... What I've been able to discern so far is that in low-speed cornering, it seem a little harder to stand back up. Like it wants to stay over and just keep going around in a circle. I like having it a little closer to the ground, but that wierd feeling like it's going to tip over now is something I think I'd rather do without.
When I get back to Seattle next month, I'm going to see if I kind find a machine shop to make a couple pairs of dogbones in a couple different lengths to try. After, of course, removing and measuring the existing, stock 'bones.
__________________
#7 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Today, a Puig windscreen arrived from Sportbike Track Gear (ebay)
__________________
#8 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Recently installed Steve's aTRE. Didn't notice much of a power difference, but did find that shifting was smoother.
And another less fuzzy pic of the bike with the new windscreen... ![]()
__________________
#9 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
1/9/2014:
Installed RaceTech .90 Kg/m springs, RaceTech Cartridge Emulators and 20wt fork oil. Damper rods drilled with 2 additional 5/32" holes rather than increasing diameter of existing 4 holes. Emulator preload at 2 turns out (default). Fork preload at 2-1/2 rings showing. On stands getting ready for disassembly: ![]() Forks off: ![]() Damper rods drilled (back in fork tubes), New spacers cut, getting ready for re-assembly... ![]() Thanks O.C. SV650S for all the help!
__________________
#10 |
Greetings Program
Bikes: '06 SV650N
Miles Kms: >60k
Installed my new RennTec "luggage" rack (it might be big enough for a 6-pack...)
Mounting: Better idea of the size: Right about 13,800 on the clock now.
__________________
Sponsored Links | |
Advertisement
Thread Tools | |
Display Modes | |
