How To: Koso Gauge Installation - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 10-19-2009, 10:11 AM   #1
jfw9
Senior Member
jfw9's Avatar
Bikes: 2002 sv650s
I decided to write this up as a review of different threads and advice given to me while I was installing this. Special thanks to Nille, 2001chromo and others who helped me via PM.
First is the wiring. The instructions provided by Koso were pretty straight forward but badly translated. For the wire that turns the unit on in response to the key switch, I used the wire for the backlight of the stock gauges.
I wired the tach in series with the negative lead for the front coil. Make sure to change the tach setting on the gauge to 4 cycle, 2 pistons.
You can mount the speed sensor on the left front brake caliper off of the bolt which holds a clip for the original speed sensor. The wheel circumference of a stock SV front wheel is approx 18,100mm. My speedo was still giving me trouble. For troubleshooting the speedometer see the end of this write up.
As far as mounting the gauge, people have given me different ideas. The one that worked for me is shown below. The gauge comes with its own bracket, which I mounted using stainless steel brackets from the hardware store using two bolts which were happily in the perfect spot under the top triple.
Finally the much discussed gas light. There are different ways to do this, I opted for the path of least resistance: an incandescent dummy light. For this, go to radio shack and buy a 'bayonet base with lens' bulb holder (part# 272-325) and some flashlight bulbs (part # 272-1112). Get out your soldering iron and solder on some wire leads. You can then wire this to either the 'you need gas' sensor, red/black wire or the 'you really need gas sensor', black/light green wire. The other lead should connect to orange green. You could also do two lights for both sensors, in which case they share a ground. I only did one for the higher level sensor. The light is mounted in a little piece of plastic just below the tach.
To do this with LED lights see post # 24 of this thread. http://forum.svrider.com/showthread.php?t=45256
To try and do something using the gas level indicator in the gauge see post #44 of that thread and let me know what you work out!
For oil and water you temp you need the adapters from Koso. The oil temp adapter is sized M16x1,5. This screws in place of the oil gallery plug and the little sensor that comes with the speedo threads into it.
For water temp you need this:
You need a 26mm. Here's a pic of it mounted on Nille's bike:
Finally, clean up the wiring, you can fit most of it inside the headlight housing.
That just about covers it! For speed sensor trouble shooting read on!
i had a defective sensor, here's the order of action to trouble shoot the speed sensor:
1. Be sure the sensor is lined up directly over the magnets.
2. Be sure the 'N' side of the magnets face the sensor.
3. Check all connections.
4. If still no good, ground the gauge directly to the battery and try it.
5. Move the sensor directly over a magnet, it can even touch, if still no reading you may have a defective sensor.
6. To rule out a gauge or connection problem, where the speed sensor connects to the gauge, bridge the outer wires of the connector on the gauge side using a piece of wire, you should get a reading. If this doesn't work, call Koso.
jfw9 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-19-2009, 10:14 AM   #2
jfw9
Senior Member
jfw9's Avatar
Bikes: 2002 sv650s
Re: How To: Koso Gauge Instalation
And I mis-spelled 'installation' in the thread title... new thread title FAIL.
Old 10-19-2009, 10:21 AM   #3
intel_killer
Senior Member
intel_killer's Avatar
Send a message via AIM to intel_killer Send a message via Yahoo to intel_killer
Quote:
Fix't for ya!
intel_killer is offline   Reply With Quote
Old 10-19-2009, 10:55 AM   #4
nille
Senior Member
nille's Avatar
Bikes: SVN 650
Miles Kms: quite some...
Send a message via ICQ to nille Send a message via MSN to nille
Re: How To: Koso Gauge Installation
...Not sure what size, I think 22mm. I ordered the wrong one...
Nah, don't do it again
You need 26mm
__________________
nille is offline   Reply With Quote
Old 10-19-2009, 11:02 AM   #5
barwell1992
Senior Member
barwell1992's Avatar
Bikes: sv650R nekid ;) k3
Miles Kms: 25,000 miles
is that 26mm the inner diamiter of the pipe ? if so thanks so much been trying to find that out so i can make some braided lines up for the rad
barwell1992 is offline   Reply With Quote
Old 10-19-2009, 11:12 AM   #6
jfw9
Senior Member
jfw9's Avatar
Bikes: 2002 sv650s
Quote:
You need 26mm
Thanks! Edited the post to include the proper size.
Old 10-20-2009, 03:45 PM   #7
Zuki
Titanium Member
Zuki's Avatar
Bikes: 04 Yellow SVS, 05 White SV
Is the info about the temp sensors the same for the 1st and second gens?
oil M16z1,5 and water 26mm ??
__________________
Always to be there with us, keeping your feet on the pegs and your right hand cranked
22 69 95
Zuki is offline   Reply With Quote
Old 10-20-2009, 08:59 PM   #8
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
.. Finally the much discussed gas light. .... You can then wire this to either the 'you need gas' sensor, red/black wire or the 'you really need gas sensor', black/light green wire. Ground it to white/black. ...
The Red/Black or the Black/Lt Green are actually providing the 'ground' through the thermistors - surely you mean to connect the opposite end of the bulb to +12V (Ignition Power - Orange/Green), not 'ground'
Incidentally ground is Black/White (not White/Black)
... http://forum.svrider.com/showthread.php?t=45256
To try and do something using the gas level indicator in the gauge see post #44 of that thread and let me know what you work out!.....
No disrespect to the OP of that post, but it seems a bit pointless (to me anyway) - it's not a 'level indicator' just an alternate means of displaying what the low fuel level warning light does.
D'Ecosse is offline   Reply With Quote
Old 10-23-2009, 12:19 PM   #9
Zuki
Titanium Member
Zuki's Avatar
this might be a dumb question by why cant you use the stock temp sensor. I mean take the wire that send the temp to the stock gages and connect it to the koso temp wire thats coming out of the gages?
__________________
22 69 95
Old 10-23-2009, 12:45 PM   #10
jfw9
Senior Member
jfw9's Avatar
Bikes: 2002 sv650s
Quote:
It reads at a different resistance. When you connect it that way the gauge reads 250F or something like that. You could make it work with different resistors but I didn't feel like testing them, and the adapters are easy.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
KOSO/Trailtech style gauge for SV 1000? Nycsv SV Modifications and General Maintenance 3 10-03-2014 10:22 PM
Fuel gauge/light with Koso? jts628 SV650 Gen1 (99-02) Tech 6 07-23-2013 09:26 PM
Anyone install a Koso RX-1N GP Style Gauge on a 2nd gen sv650s? JohnnyUtah SV650 Gen2 (03-15) Tech 9 07-03-2012 11:52 AM
koso gauge takis100 Motorcycle Talk 3 10-28-2008 03:48 PM
1999-2009 SVRIDER.com.
