SV650 Dealer Mode Error Codes - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 09-05-2009, 03:13 PM   #1
mg66
Senior Member
mg66's Avatar
Bikes: '08 SV650ST
Miles Kms: Quite a bloody few and counting
I have seen members ask about error codes in dealer mode so I copied the codes from the 2003+ dealer service manual.
If this is a repost, my bad but a quick search didnt find anything. Hope this helps members.
__________________
mg66 (FIGJAM) ... Four wheels move the body. Two wheels move the soul. ~ Author Unknown
http://sv650.metromain.net/sv_pics/svs_logo.jpg
mg66 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-05-2009, 03:26 PM   #2
Cali_Greens
Senior Member
Cali_Greens's Avatar
Bikes: 03 SV1000
Miles Kms: 22000
Re: SV650 Dealer Mode Error Codes
Very helpful
Thanks!
Cali_Greens is offline   Reply With Quote
Old 09-06-2009, 04:26 AM   #3
Spierings
Senior Member
Spierings's Avatar
Bikes: k3 sv650n
And also a how to:
1: You will need to make your ‘dealer mode tool’…
Simply take a piece of wire about 3 inches long and strip back about 8mm of the insulating sheath (twist the cores together on multi-core cable). Snip off the last 2-3mm with a pair of scissors or a wire cutter to leave a clean end.
: Undo & remove the pillion seat.
2: Locate the Dealer Mode Activation Connector
If you look into the tail unit from behind, on the left hand side you should see a bunch of a few wires & connectors behind a bit of plastic protruding from the undertray.
Follow this bit of plastic down towards the rider’s saddle and you should find another connector. It’s rectangular, white plastic with 6 holes for connectors in and only 4 of them used. It also has a black rubberised cover on it.
3: Turn off your ignition and put your ‘dealer mode tool’ in the two terminals that are next to each other.
**WARNING**
Do NOT short out the wire onto the chassis or any other part of the bike. Do NOT connect either of the other two terminals to anything.
4: With the ‘tool’ still in the connector turn on your ignition. The temperature display should have disappeared and now you will see a little line (like a minus sign), the letter c followed by two zeros. If you have any other numbers shown in this display, see below to diagnose your bike’s fault.
CODE MALFUNCTION PART REMARKS
COO None No defective part
C12 Crankshaft position sensor (CKPS) Pick-up coil signal, signal generator
C13 Intake air position sensor (ZAPS)
C14 Throttle position sensor (TPS)
C15 Engine coolant temperature sensor (ECTS)
C21 Intake air temperature sensor (IATS)
C23 Tip over sensor (TOS)
C24 Ignition signal #1 (IG coil #1) For #1 cylinder
C25 Ignition signal #2 (IG coil #2) For #2 cylinder
C28 Secondary throttle valve actuator (STVA)
C29 Secondary throttle position sensor (STPS)
C31 Gear position signal (GP switch)
C32 Fuel injector signal #1 For #1 cylinder
C33 Fuel injector signal #2 For #2 cylinder
C41 Fuel pump control system (FP control system) Fuel pump relay
C42 Ignition switch signal (IG switch signal) Anti-theft
C49 PAIR control solenoid valve
__________________
My build thread:
http://forum.svrider.com/showthread.php?t=117161
Spierings is offline   Reply With Quote
Old 11-12-2009, 03:36 PM   #4
pile o' sv
Member
pile o' sv's Avatar
Bikes: '09 SFV650
Miles Kms: 8216
One question. If your bike doesn't have the stock cluster, I'm running a trail tech, how are you to retreive error codes?
pile o' sv is offline   Reply With Quote
Old 11-12-2009, 04:16 PM   #5
Spierings
Senior Member
Spierings's Avatar
Bikes: k3 sv650n
Quote:
You need stock gauges to retreive the error code.
You can only do this on a second gen and not your '01 SV650 S Nakedized.
__________________
My build thread:
Old 11-12-2009, 04:19 PM   #6
friendlyfoe
Senior Member
Bikes: 08 SV650
Miles Kms: 10 000km's
lol ya you'd kind of need a computer to pull codes....
This thread should be cleaned, locked and stickied......seriously
EDIT: oh to add tho, on my 08 the dealer mode plug is under the right rear corner of the gas tank, can get at it by removing the little side cover, not sure what year exactly but it got moved at some point.
__________________
Quote:
Originally Posted by bfeils View Post
If it happens again touch the headers and see if one of them is much cooler than the other. Do it very quickly obviously so you don't get burned.
friendlyfoe is offline   Reply With Quote
Old 11-12-2009, 05:32 PM   #7
pile o' sv
Member
pile o' sv's Avatar
Bikes: '09 SFV650
Miles Kms: 8216
I should put in there somewhere that I'm converting to fuel injection. No more carb tuning for me.
Old 11-13-2009, 08:10 AM   #8
Spierings
Senior Member
Spierings's Avatar
Bikes: k3 sv650n
I should put in there somewhere that I've converted to fuel injection. No more carb tuning for me.
We want some pics, to prove it
__________________
My build thread:
Old 04-13-2012, 07:26 PM   #9
sdGallant
Member
Bikes: 2008 SV650S
Miles Kms: 8500 km
i know this is old, but this post was a savior
sdGallant is offline   Reply With Quote
Old 11-25-2012, 07:20 PM   #10
ApolytonJS
Junior Member
Bikes: 2008 Suzuki SV650 K8, blue
Miles Kms: 14,000 miles
Question Re: SV650 Dealer Mode Error Codes
Is it important to unplug the other 4 connectors before inserting the tool?
ApolytonJS is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gladius/SV Dealer Tool for Error Codes bahamutcog Motorcycle Talk 3 07-27-2017 11:40 PM
09 Gladius - Dealer Mode Connector / Tool Error Codes bahamutcog Gladius forum 0 07-25-2017 09:26 PM
Error Codes but no real codes ronnyek SV650 Gen2 (03-15) Tech 6 04-14-2012 11:24 PM
Asking for "coupon codes" or "promotional codes". SnootyBikeMike Motorcycle Talk 16 07-26-2010 02:59 PM
Error code C42 in dealer mode sbbsnewman Motorcycle Talk 2 03-12-2009 12:46 PM
1999-2009 SVRIDER.com.
