S to N conversion - silly question - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 07-09-2019, 10:36 AM   #1
fz6yamaha
Member
Bikes: SV 650 2001
Miles Kms: 17000
Guys, hello, I am back, I tried, well I did sell the SV, ended up with other bikes, got a GSXR-750 for track as the SV was been beat and she did not deserve that, so I sold it and said I will get a second bike, something different something bla bla bla and could not resist and ended up getting another SV650 again, I think we are addicts
Well enough said, I know got an 06 S model, previously 00 n model, of course I do not need the clip ons and the pain, I got the GSXr for that, and the SV to relax me ,
I seen all threads about the bar conversions, the triple tree, etc, but I have not seen anyone talking about just drilling couple of holes on the current triple top and installing one of those bar clamps like the one's used in the N model., I believe I do not need to change the triple, i can adventure and just pop those clams in there, drill 1 or 2 holes to attach them and just mount the bars...get SS lines and longer cables and thats about it.
But I just do not see why I could not just do that.
Any warning or word of caution?
fz6yamaha is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-09-2019, 01:15 PM   #2
steveSLO
AARP Moderator
steveSLO's Avatar
Bikes: '08 SV650N/abs
Miles Kms: 20,000
Re: S to N conversion - silly question
It's been done, and I have never heard of a problem.
I would suggest thick washers above and below the triple to distribute the stresses.
__________________
Experience. Something you get just after you needed it.
steveSLO is offline   Reply With Quote
Old 07-09-2019, 03:46 PM   #3
jeff721
Senior Member
jeff721's Avatar
Bikes: K6 Sv650 Naked
The only concern that I would have is if there is any structural "webbing" on the underside of the top triple. If so you may need to grind it away in order to fit the nut and washers on the underside.
Most people just opt to buy a triple from an N model to save themselves the time and energy. Sometimes you can source them with the clamps for less than a good set of aftermarket clamps alone.
jeff721 is offline   Reply With Quote
Old 07-09-2019, 08:07 PM   #4
steveSLO
AARP Moderator
steveSLO's Avatar
Miles Kms: 20,000
N uppers and S steering stems have different angles,
although some scammers will deny this.
If they were the same, there would be only one part number for all steering stems.
But there are four, and you can't tell what you've got by looking.
Click image for larger version
Name:	all steering stems.jpg
So first you have to find a set of matching upper and lower clamps guaranteed to be from an N.
Then you buy the special tools to remove and replace the parts.
Buy and install new steering stem bearings at the same time,
since this is the last time you will ever want to do this.
By the way, the underside of the S part does have a pattern embossed,
so maybe a bit of bondo for the bottom washers:
Name:	sv650s top clamp.jpg
__________________
Old 07-10-2019, 03:46 PM   #5
Cherryriver
Junior Member
I just went ahead and drilled two 10mm holes in our S's top clamp and threw on an inexpensive set of riser/clamps. Working fine for 2500 miles.
It does get tight on the right side one near the ignition switch boss, so don't go wide. I wound up cutting a straight onto the underneath washer. Tough getting a wrench on it, too.
Extending the wiring cables is the next pain. The Motion Pro extended control cables were fall-off-a-log easy and it needed new cables anyway.
Cherryriver is offline   Reply With Quote
Old 07-11-2019, 12:06 PM   #6
fz6yamaha
Member
Bikes: SV 650 2001
Miles Kms: 17000
I am glad I am not alone ,
I just could not find a reason not too. CherryRiver where did you get the inexpensive clamps?..I been looking up ebay and there is like a million of option, I am trying to stay away from the China one to avoid the delayed shipping.
I was about to replace the brake lines anyway, always have SS on all bikes, cables are the next thing to order.
If you can post few pics of your setup that would be nice..
and as always thank you all a bunch for your help.
Old 07-11-2019, 12:46 PM   #7
Junkie
Senior Member
Bikes: 06 1k
https://www.ebay.com/itm/Pair-Of-Han...MAAOSwfCpbH0Zz claim to be in TX so it shouldn't take too long to arrive
__________________
06 SV1000: 06 600 forks, Penske triple, Carrozzeria wheels, TopYokes triple, upright bars, RCS19, R6 calipers, OSF rearsets, full M4, Monster seat on custom subframe, JW Speaker Adaptive headlight
Junkie is offline   Reply With Quote
Old 07-12-2019, 06:49 PM   #8
fz6yamaha
Member
Bikes: SV 650 2001
Miles Kms: 17000
Thanks Junkie,
I saw those, the only thing I did not like was the bolts they used, so I ended up going with this set (I am not sure if I am allowed to post links but here it goes - apologies moderators if I cannot)
https://www.ebay.com/itm/2pcs-7-8-22....c100005.m1851
Old 07-12-2019, 07:02 PM   #9
Cherryriver
Junior Member
Here's my Heli Multi Tour Sport bars conversion.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
