Clean and Simple CBR600 Build - Page 5 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > The Build Board
The Build Board A place to post a journal or log of your SV / Gladius projects and builds. No replies or discussion are allowed.
Reply
Thread Tools Display Modes
Old 12-02-2010, 08:45 AM   #41
Knifemaker87
Senior Member
Knifemaker87's Avatar
Bikes: White 'n Blue 2006 SV650S
Miles Kms: 7.5 k
Send a message via AIM to Knifemaker87
Re: Clean and Simple CBR600 Build
I did get some work done...
"stock" headlight brackets
most of the machining done
and on the bike.. sorry for the crappy pictures.. i left my camera at work.
gonna do some CF work next...
Knifemaker87 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-06-2010, 09:42 AM   #42
Knifemaker87
Senior Member
Miles Kms: 7.5 k
I made another set of side-covers, this time using a vacuum bag system. I got my mold ready by cleaning it, waxing it, and then sprayed it with a florocarbon dry release agent.
Then i got all my materials ready. 5 layers of carbon fiber of varying orientations, weaves and weights. I also cut out the peel-ply, breather, and thick fiberglass to soak up the extra resin.
after applying the resin and cloth, i put it all in a bag, and pull it down under a vacuum. the peel-ply keeps everything from sticking to the part.
once it has cured, i pull it out of the bag
then i pull everything off the part and see how i did... not bad.
These parts were mostly to pilot vacuum bagging the tail... but i needed extra side-covers anyway.
tail comes next.
Old 12-08-2010, 02:11 PM   #43
Knifemaker87
Senior Member
Miles Kms: 7.5 k
fitting the side-cover
Gratuitous shot...
Mold prepped
and primed
Sounds like i will be getting some USD forks, in trade for some knife work... as it is part of the job... i will put it all up here
thanks Zach!
Old 12-09-2010, 06:55 AM   #44
Knifemaker87
Senior Member
Miles Kms: 7.5 k
okay... update time here...
USD forks are going to be MINE! bwahahahaha
Quote:
Originally Posted by fslflint
heres the pics I could find of the front end. I think I can make the yokes look allot better with some minor machine work
now i just need to source some new 320mm dia rotors that will fit a f2 rim... that are super cheap. any ideas?
Old 12-10-2010, 06:20 AM   #45
Knifemaker87
Senior Member
Miles Kms: 7.5 k
okay... well, apparently what i need are 2004-2006 R1 front rotors. anybody got any they would be willing to part with? Hit me up.. we can work something out.
Okay.. on a side note, i am trading a knife for these forks, so i thought i might put in some simplified info and picture about making the knife.. as it is actually build related.
okay.. always gotta start out with a plan, even if it is in your head, otherwise you just make crap. so.. here is a drawing. i had several things to go on; blade is 5" or less, very thick tough blade to put up with abuse, a drop point, and a modern tanto tip. so, here you go:
then i sawed it out (roughly) and profiled it on the grinder. i forgot to say, this is 5160 spring steel.
then i rough round in the bevels. I will heat treat it next before drilling the handle pin holes and lanyard hole.
more to come soon
~Chris
Old 12-18-2010, 08:25 PM   #46
Knifemaker87
Senior Member
Miles Kms: 7.5 k
Well... i have an update for you.
Knife work:
I cut out the handle material. Horse stall mat; the ultimate handle material
cut the holes and transferred them to the handle material
then i roughed the handle out and glued it on before flaring the tubes. the string holds it tighter than clamps
glue dry, string off,
and.. the finished product ready to cut
i have been doing some machine work as well.
new 50mm headlight clamps... (there are 16 of them total)
and the beginnings of a clip-on
and... here are the finished clip-ons. i am re-making the bars with a solid stainless stell adapter and beef up the screws to 1/4-20's the clamps and bars are 6160-t6 aluminum and the adapters are 7075. they will be 416 stainless
So... my wife and i drove up to MD to get the front end and give Zach the knife today.
i am now in possession of a USD front end with custom triples. thanks Zach!
and... i just had to try out the clip-ons
the triples will be getting a stem of their very own for Christmas as well as a face lift and liposuction. makeover time!
i cant throw out enough rep for Zach and all he was done. and Denver donated some 320 rotors. thanks man!
more to come...
Old 12-21-2010, 01:31 PM   #47
Knifemaker87
Senior Member
Miles Kms: 7.5 k
I stripped cleaned, painted and rebuilt the brakes...
my wife rocks. in exchange for watching a chick flick with her i got to do all the brake work on the coffee table instead of the freezing garage!
Old 12-23-2010, 08:39 AM   #48
Knifemaker87
Senior Member
Miles Kms: 7.5 k
I have been pulling 12 hour days for the last week trying to get this project we are working on done, but some of the time i am just watching the machine run... so i got some work done on the top triple.
Here is how it started out.
I set up the 50mm slug to center the triple on the turntable so that i could switch sides without having to setup every time.
slimmed down a bit
I then laid out my lines to cut the pockets.
i still need to do the final passes and clean everything up, but here is what it looks like now.
I also found out that i get Christmas Eve off, so i will be trying to knock out the final CF tail while my wife is at work.
thanks so much!
~Chris
Old 12-29-2010, 07:56 AM   #49
Knifemaker87
Senior Member
Miles Kms: 7.5 k
I was kinda busy this past week/weekend. Merry Christmas! we also got a foot of snow, canceling our holiday travels, so i did get the tail made:
Cloth prepped and ready
ready for a little hand-work. sorry i didn't get more pictures. i kinda hand my hands full.
I also got an F3 wheel from a guy here at work to play around with. I will prolly end up taking it off his hands so i can use the 320mm rotors i have.
And i took the OEM front end off to pull out the steering stem to put it in the new triples.
And... as it turns out, the triple that i cleaned up is the lower triple. Oops. i thought it was the top.
more to come soon. working 12 hour days over the holidays...
Old 12-30-2010, 09:52 AM   #50
Knifemaker87
Senior Member
Miles Kms: 7.5 k
I do have a small update:
I pulled the stem out of the old triple. well the existing hole in the new triple fit perfectly. for a press fit. I did want some assurance however that it wouldnt be coming back out, but i couldnt weld it since the triple is aluminum and the stem is steel... so... i threaded the inside of the stem.
Sadly, the only thread that would work was a 1"-20 so i tapped it. easy work. then... i find out they dont even MAKE 1"-20 bolts... so.. now i need to make a "bolt" (pictures later today)
I was able to slap the forks on. the top triple needs to be modified to accept the stem, but otherwise...
more coming today...
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Clean and Simple II Virago Knifemaker87 Motorcycle Talk 498 07-05-2015 03:59 PM
Clean and Simple CBR600 Build Knifemaker87 Motorcycle Talk 1305 05-07-2012 03:32 PM
Clean and Simple CBR 600 All carbon fiber w/868 miles (Tidewater VA) Knifemaker87 Bikes For Sale 15 05-04-2012 01:38 AM
simple build/upgrade. nsra_23 The Build Board 7 07-08-2011 05:43 AM
Simple Question. Simple answer? jamesconner31 Motorcycle Talk 10 04-20-2009 08:39 AM
1999-2009 SVRIDER.com.
