Gen 2 Helmet Holders - Flawed Design? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > SVRider Motorcycling Forum
SVRider Motorcycling Forum Our main message forum catering to the Suzuki SV and general motorcycle chatter.
Reply
Thread Tools Display Modes
Old 09-08-2018, 07:36 PM   #1
matteblacksmoke
Junior Member
Bikes: 2016 KTM rc390, 2005 sv650s (yellow)
Miles Kms: 20k rc390, 17k sv650
The fairing on my '05 sv650s has cracked from using the helmet holders that are built in underneath the passenger seat. I haven't found much talk abou these online and the owner's manual, page 3-18 merely says "Hook your helmet on the helmet holder and lock the seat". I have a Shoei rf-1200 and am looping the metal hoops onto the helmet holder, then draping the helmet on the side of the bike as expected. See imgur album:
https://imgur.com/gallery/TCW8gyl
Am I using these wrong, or is this just a poor design that will usually result in a cracked fairing? I really liked these when I first got the bike and thought it was a great convenient feature, but now I have a big hole in the fairing that will let water and rain into the compartment under the seat unless I tape it up or find some other solution. Has anyone figured out a good way to use the helmet holders without breaking the fairings? Are there any clever aftermarket products I can get that will fix this part of the bike up?
matteblacksmoke is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-08-2018, 11:49 PM   #2
snailman153624
Senior Member
Bikes: '04 SV650
Re: Gen 2 Helmet Holders - Flawed Design?
Looks like the 2nd D-ring smashed into the plastic.
On the rare occasions I've used this, I put both D-rings on the hook. However, I find it's a hassle to take gloves off and place them on the seat, get key out of ignition and put it in the rear lock, remove the rear seat then realize I have nowhere to put it, hear the gloves slide off the seat (one on each side of the bike...but hey, now I have a spot to put the rear seat), remove helmet, fiddle with the D-rings until they slip on, feel the rear seat slide and hit my foot...
Bend down, grab the rear seat, snap it on, remove key, get one glove, walk around to other side, get other glove, etc etc.
I usually just bring my helmet inside wherever I go. It fits fine in a grocery cart, or on a shelf or desk.
Won't get damaged or stolen, either.
snailman153624 is offline   Reply With Quote
Old 09-09-2018, 01:29 AM   #3
svbhoy
Member
Bikes: 2007 SV650S
Miles Kms: 7300
Been using mine for years without issue,.i only use one ring and it can be a bit of a pain but it works without damaging anything. My wife's Honda came with a cable (as the cbr500r has an even worse design) and that would make it easier. Just loops through d-rings and hooks over the hook under the seat...less chance of an unyielding d-ring cracking bodywork.
Looks like you're using it right, but it is tight and ff could be out got twisted and...snap.
In terms of fixing it, you might try a fiberglass repair kit. Lots of sanding and painting fun...or hit the wreckers, buy new replacement piece, etc.
__________________
Always remember, no matter where you go, there you are.
svbhoy is offline   Reply With Quote
Old 09-09-2018, 05:04 AM   #4
stewart
Member
stewart's Avatar
Bikes: 2017 SV650
Quote:
The 2017 doesn't have a helmet holder at all. I used the one on my 2007 a few times without issue...hooked the d-ring to it just like in the picture. It's a bummer what happened to your fairing matteblacksmoke.
I think someone experienced with body work might be able to put that piece on. Looks like you could maybe epoxy it back into place since it's sort of hidden by the seat. Maybe not, just a thought.
stewart is offline   Reply With Quote
Old 09-09-2018, 12:36 PM   #5
golden chicken
Senior Member
golden chicken's Avatar
Bikes: 2005 SV650n
Miles Kms: 58,000
My helmets' D-rings always sat entirely inside the tail fairing and the seat and fairing just have to clear the strap.
__________________
Have a nice ride.
golden chicken is offline   Reply With Quote
Old 09-09-2018, 11:50 PM   #6
eddiemon
Chief Greeter
eddiemon's Avatar
Bikes: 07 SV650 - 86 atc250R - 85 BW200
Yea I also hook both rings onto the helmet holder.
My buddy Kim bought a new Shoei helmet and they replaced the rings with a racket lock setup?
__________________
eddiemon is offline   Reply With Quote
Old 09-10-2018, 08:42 AM   #7
steveSLO
AARP Moderator
steveSLO's Avatar
Bikes: '08 SV650N/abs
Miles Kms: 20,000
I just ordered one of these. I'll post my findings in a few days.
Click image for larger version
https://www.amazon.com/Lock-It-Strap...6586484&sr=8-1
__________________
Experience. Something you get just after you needed it.
steveSLO is online now   Reply With Quote
Old 09-10-2018, 01:59 PM   #8
golden chicken
Senior Member
Bikes: 2005 SV650n
Miles Kms: 58,000
Mostly I just take my helmet with me. I envision people tampering with it while I'm away and shudder to think of the things I might unknowingly put on my head when I come back.
__________________
Have a nice ride.
Old 09-10-2018, 11:06 PM   #9
matteblacksmoke
Junior Member
Thanks for the input all. Getting 2 D rings on and off is a major hassle so I may just stop using this, or maybe build in some sort of rubber gasket that flexes when I use the helmet holder and keeps water out. I enjoy the convenience. The cables some of you suggested are also a good idea.
Old 09-11-2018, 08:58 AM   #10
steveSLO
AARP Moderator
steveSLO's Avatar
Miles Kms: 20,000
Quote:
Originally Posted by matteblacksmoke View Post
Thanks for the input all. The cables some of you suggested are also a good idea.
I bought the one on Amazon because it is a steel cable between two web straps.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Looking for concept design ideas - futuristic motorcycle design on top of an SV base superwormy SVRider Motorcycling Forum 3 04-30-2009 02:42 PM
Toll pass holders for bike riders? hatchetman240 SVRider Motorcycling Forum 10 05-24-2007 07:37 PM
DougZ plate holders, round two...feeler... DougZ SV Modifications and General Maintenance 7 04-19-2007 02:04 PM
Production design vs. MotoGP design Jacques SVRider Motorcycling Forum 4 02-20-2007 06:37 AM
bar end holders pattonme SV Modifications and General Maintenance 3 12-20-2006 06:33 PM
1999-2009 SVRIDER.com.
