Hi all,
Working on a 01 SV650S with 35k miles, backfires at idle but runs like a gem above 2k rpm. Stock headers with a yoshimura Tri Oval dual exit pipe, stock intake, tank lifted, 17.5 pilots and 136 mains. Pilots are fresh, mains were pulled and cleaned, and stuck some fresh CR9-E plugs in.
I'm open to ideas, air getting into the exhaust somewhere? needs valve job?
Thoughts?
Thanks
Gitter
Edit
(incase you didn't want to read all four pages of the thread)
Problem solved:
Checked the valves, exhaust valves were a little tight. Adjusted the valves back into spec and synced the carbs. Fixed the popping issue at idle.
Thoughts?
Thanks
Gitter
Edit
Problem solved:
