FI light - error code c32 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 10-30-2007, 10:21 PM   #1
jreiter
Member
jreiter's Avatar
Bikes: 2007 SV650
Send a message via AIM to jreiter
Howdy folks. Been having the FI light come on now and then ever since I installed a Power Commander III. I was finally able to catch the FI light while I had my tools handy, and thus was able to jump the diagnostic pins and retrieve the error code. The code is c32. Does anyone have a manual handy and can tell me what this code means?
I only seem to get this error when the bike is cold. (In the mornings on my way to work, for example, after the bike has sat all night.) After the bike has warmed up, the code doesn't seem to show up. I've already emailed DynoJet about it, but still waiting for a response. Figured I'd check in with you all as well to see if you had any suggestions.
Thanks!
jreiter is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-30-2007, 11:59 PM   #2
YZEtc
Senior Member
YZEtc's Avatar
Bikes: 2009 WR-250F & 2008 WR-250R
Miles Kms: Approx. 400 & 2,300
Send a message via AIM to YZEtc
Re: FI light - error code c32
The exact words in the SV-650K7 section say:
Detected Item: Fuel Injector
Detected Failure Condition: CKP sensor (pickup coil) signal is produced, but fuel injector signal is interrupted (front 8 times, rear 8 times) or more continuously. In this case, the code C32 (PO201) or C33 (PO202) is indicated.
Check for: Fuel injector, wiring/coupler connection, power supply to the injector
YZEtc is offline   Reply With Quote
Old 10-31-2007, 12:19 AM   #3
jreiter
Member
jreiter's Avatar
Bikes: 2007 SV650
Yeah, that doesn't surprise me. The PCIII leeches its power off of the fuel injectors, which always seemed a bit weird to me. (Rather than having its own power supply.) It must be leeching a bit too much, and causing the fuel injector to not respond right. Hmm... that's a bummer. Hopefully DynoJet will have some suggestions...
Old 10-31-2007, 09:30 AM   #4
Kris87
Senior Member
Kris87's Avatar
if you have an 07, which i assume you do by your sig, the only racer i know that had a pc on his 07 racebike couldnt make it work either. it was actually the first pc for the 07 dynojet sent out. it caused all kinds of funky code problems when he ran it. he eventually took it off, and raced with the stock ecu. no problems after that.
i told you all PC are the devil.
__________________
Kris Wall Ex#87
2007 Wera Sportsman LWTSS, F2, D Sbk, Clubman National Champion
2009 Wera National LWT SS Champion
Kris87 is offline   Reply With Quote
Old 10-31-2007, 01:22 PM   #5
jreiter
Member
jreiter's Avatar
Bikes: 2007 SV650
Yeah, I'm beginning to think that way as well. The new '07 system, with dual spark plugs per cylinder, O2 sensors, etc, might just be too much for a simple piggy-back unit like the PCIII. An ECU reflash would probably be the best bet, but I really don't know much about that or who could *properly* do it. If this doesn't work out, I'm okay just pulling the PC out. I don't really notice any power differences with it, and honestly I didn't really care about power. The bike has plenty for me at this point in my life. I was just hoping to fix the fuel mixture to account for the exhaust I got so the bike wouldn't run too lean and cause long-term problems.
Old 11-23-2007, 11:09 AM   #6
lamtaiii
Member
Bikes: 2007 k8 sv650
Miles Kms: 1000
problem solve?
i have the same error after intalling powercommander.
my car get warm, when i make the large throttle the fi light came.
first gear after making wheelie.
fouth gear with large throttle.
lamtaiii is offline   Reply With Quote
Old 11-25-2007, 03:52 AM   #7
jreiter
Member
jreiter's Avatar
Bikes: 2007 SV650
No luck for me. Dynojet said it might be a bad connection, and that I should check all my connections. I checked everything, made sure all the plugs were secure, and the problem still occurs.
Old 11-26-2007, 09:20 PM   #8
Krautwagen
Member
Krautwagen's Avatar
Bikes: '07 SV650n
Miles Kms: 9700
My '07 also does this - but IIRC, it did happen once before I installed the PC3. Dealer said might be a bad ECU, but didn't know. I still haven't dropped it off to have them look at it...
__________________
Dave
'07 SV650 Nekkid
Krautwagen is offline   Reply With Quote
Old 01-11-2008, 03:34 PM   #9
lamtaiii
Member
Miles Kms: 1000
fi light error has been solved by dynojet.
using firmware 2.1.2 for powercommander.
the fi light will not come on again.
the performance is same as before.
Old 02-18-2008, 01:07 PM   #10
jreiter
Member
jreiter's Avatar
Bikes: 2007 SV650
Has anyone else gotten the firmware update lamtaiii mentioned above? Any luck with it?
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bike Won't start-FI light and C42 error code [email protected] SV650 Gen2 (03-15) Tech 13 05-09-2016 12:18 PM
05 sv650 fi error- code is c42 ryan1clancy SV650 Gen2 (03-15) Tech 6 02-29-2016 11:05 PM
C32 error code- bike with PCIII cwok80 SV650 Gen2 (03-15) Tech 3 05-10-2015 01:36 PM
Wierd FI error code issue Solid Soup SV650 Gen2 (03-15) Tech 14 03-25-2012 11:17 PM
Code 28 error, ECU isn't holding the code crazyhawk99 SV650 Gen2 (03-15) Tech 7 04-05-2011 11:24 AM
1999-2009 SVRIDER.com.
