05 sv650 fi error- code is c42 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 02-06-2016, 12:19 PM   #1
ryan1clancy
Junior Member
Bikes: Sv650 '05
2005 sv650 just started with with fi error, found out the code is c42 something to do with ignition, no work has been done to bike and just started, can get bike to start by doing sequence of turning kill switch on and off till error code goes.. See thread already with video and looks like same thing in video.. Help?!?
https://www.svrider.com/forum/showthr.../189241?page=1
ryan1clancy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-06-2016, 02:48 PM   #2
n1xxl
Junior Member
Bikes: suzuki sv650
Miles Kms: 1000 miles
Re: 05 sv650 fi error- code is c42
C42 is ignition input to ecu not present. Check the 4 pin green connector below tank open and spray in contact cleane then remake. If you have a volt meter you should have around 6vdc from the orange/ red wire to ground when the ignition is on. If not likely the ignition switch at fault.
n1xxl is offline   Reply With Quote
Old 02-07-2016, 09:26 AM   #3
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Quote:
Originally Posted by ryan1clancy View Post
... See thread already with video and looks like same thing in video.. Help?!?
The problem in that video was due to a wiring error. Sounds like your problem is flaky anti-theft contacts inside the ignition switch. Different.
Have you ever used graphite to lubricate the ignition switch?
With the ignition switch ON and Run/Stop switch set to STOP does your gauge show "FI" or just "CHEC"?
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Old 02-24-2016, 12:20 PM   #4
vilago
Senior Member
vilago's Avatar
Bikes: 2008 Gray SV650N
Miles Kms: 27K Miles
TeeRiver,
you seem the expert on this issue, been having the same problem now for 2 years on my '08 (fuel pump won't prime, fiddle with key and/or kill switch a couple of times then it starts). can you point me in the direction of a step by step on how to correct the issue? My understanding is that i have to check the voltage and resistance between certain wires. is there anything simple to check first, loose connector, etc? I have never put any graphite in the ignition switch, but in order to do the front end swap i did have to use some heat on the bolts that held it onto the original triple as they had red loctite on it. hoping the heat didn't reduce the life of the ignitioion.
vilago is offline   Reply With Quote
Old 02-25-2016, 11:05 PM   #5
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Quote:
Originally Posted by vilago View Post
... i did have to use some heat on the bolts that held it onto the original triple as they had red loctite on it. hoping the heat didn't reduce the life of the ignitioion.
There is a good chance heat damaged the ignition switch resistor. Did the problem start only after heating? Was the ignition switch glowing cherry red?
If you can make it fail easily, measure voltage on the Orange/Red wire between the green ignition switch connector and the ECM. You should see about 4.5v. How far off from this value will say whether the problem is a burnt resistor or a flaky connection. With electrical repairs it is always nice to know the cause, no guessing.
Or you can simply bypass the internal ignition switch resistor with an external resistor to see if the problem goes away. If you want to do the bypass, post back for details.
__________________
Old 02-29-2016, 02:31 PM   #6
vilago
Senior Member
vilago's Avatar
it didn't start immediately after the swap, but a couple years later. it wasn't red hot but i had to really get it hot as I had become frustrated and stripped one of the screws not knowing they were loctited in at the time. let's see what your tests come back with.
Old 02-29-2016, 10:05 PM   #7
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Be aware, the bike must be failing at the time of measurement else the voltage reading will not be meaningful.
A third option is unplug the ignition switch at the green connector and directly measure resistance between Orange and Orange/Yellow. Should see a solid 100 ohm reading, if not, then the resistor or switch contacts are bad. Again, this test will only give result if the switch is currently failing.
Or as mentioned, bypass the resistor externally, 90% chance that will fix the problem.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
