C42 error code - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV1000 (03-07) Tech
SV1000 (03-07) Tech Info, advice or questions specific to 2003-2007 model SV1000. Sponsored By: Werks Parts
Reply
Thread Tools Display Modes
Old 05-10-2011, 11:13 AM   #1
BIGBUGIN
Member
Bikes: SV1000
Miles Kms: 10K
C42 error code
My bike hasn't been starting correctly lately, fuel pump Wont prime. And it has gotten to the point where it doesn't start until 15-20 attempts wiggling the key around. I've narrowed it down to a c42 error, which seems to be a recurring issue on the site. But I have yet to find a proper answer on how to fix this. I really don't want to swap the ignition, is there any recommendations from anyone out there on how to fix this?
__________________
SvRiders of South Fl-
http://www.facebook.com/pages/SvRide...69399083112773
BIGBUGIN is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-10-2011, 05:16 PM   #2
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
Re: C42 error code
C42 is the anti-theft resistor in the Key-Switch assembly
What you can do is remove the orange/red from the key-switch and connect it via 100 ohm resistor to the orange wire. You can pick up a 100ohm resistor at RadioShack.
D'Ecosse is offline   Reply With Quote
Old 10-22-2011, 03:47 PM   #3
BIGBUGIN
Member
Bikes: SV1000
Miles Kms: 10K
Re: C42 error code
Hey D , I don't have a red/orange wire comming from the key switch on my sv1k . I have two red, one orange, one orange/yellow, and brown wire. Which wires do I connect with the 100 ohm resistor?
__________________
Old 01-11-2012, 10:00 AM   #4
BIGBUGIN
Member
Bikes: SV1000
Miles Kms: 10K
Re: C42 error code
Ok I figured it out buddy... Red wire (from switch) attached to orange/yellow(in line via 100 ohm resistor)
Took a while, and I panicked a little when I didn't see a orange/red wire
Thanx man
__________________
Old 01-11-2012, 06:38 PM   #5
Exhausted
Senior Member
Exhausted's Avatar
Bikes: Suzuki - SV650N - 2008
Miles Kms: 24800mi
Re: C42 error code
I have had to get custom keys made because idiotically i lost my original key, and these keys thats were made for me from a locksmith work good, but could these be the culprit?
edit: im getting an error that seems to be just like this, and i have custom keys to boot. i dont want to take the anti-theft OUT of the bike, but should i look into either getting better cut keys or ?
__________________
Shift-positive
Exhausted is offline   Reply With Quote
Old 12-28-2014, 07:01 PM   #6
cipicu
Junior Member
Bikes: Suzuki SV650 Fully Faired 2005
Miles Kms: 27560
Hi guys, I'm new here as you are my last possible solution. My SV650 let me down on boxing day while i was going home. After I finish shopping I stopped by my friend. When i left my friend's house, I start my SV650, I let it warm up for 5 minutes as every time then i get on it and tried to go home, a mile away from my friends house the engine suddently cut off. I pulled over and i switched the key off and on, the fuel pump sound was coming on as it should but when i press the start button it wouldn't do nothing, i tried push starting it I couldn't as i was by myself and it was cold outside. I managed to get it home and today in the morning i start to remove the panels and have a look around. I checked the fuses, they allright, the kill switch, stand switch and clutch switch are allright as the pump is coming on when i test it. Then the same problem i couldn't see why it doesn't react when i pressed the start button. Anyway, I needed a break as I was too angry so i got a cup if tee and warm up for about an hour. When i got back to the bike i put the key in, turn the ignition on, the fuel pump won't come in anymore, F1 on display, i put it into dealer mode to find out the Fault Code which it was -C42 and that is quite all so far, I read some threads about this, honestly i Can't understand nothing what is out there I need a quick solution cuz i really need to ride my bike. Please tell me how to fix it, as clear as possible. Suzuki SV650 K5, Fully Faired, 2005, had it for 1 and half month, Fully Serviced 3 weeks ago (K&N Filters, EBC Brake Pads, Castrol Brake Fluid, Castrol Performance Fully Synthetic oil, -30 to +140 Degrees coolant, NGK Iridium Spark Plugs). THE BATTERY IS FULLY CHAARGED.
PLEASE HELP!!!!!!
cipicu is offline   Reply With Quote
Old 12-28-2014, 10:37 PM   #7
RecoilRob
Senior Member
Bikes: '07 SV1000S
Miles Kms: 43379
Re: C42 error code
Welcome to the Forum.
Firstly...you're in the 1K section so others with 650's might not see this...but no matter, you're here and I think we can help. The C42 says the ECU isn't seeing the correct voltage coming from the Anti-Theft resistor in the ignition cylinder. This can be caused by several things including bad connections or a worn/dirty ignition switch.
Best to check all the connections you can on the battery and starter solenoid just to make sure nothing has come loose. If all are OK, try jumping across the starter solenoid to see that the starter spins...be SURE it's in Neutral!!! If the starter runs then you can rest easy that it's good and also the wiring from the solenoid to it is sound.
The ECU setting the C42 doesn't necessarily mean the ignition switch is bad as anything robbing the rest of the bike of voltage could trip this code, but making sure the switch is clean inside a good thing to look at having this problem. The connector at the end of the ignition switch is the infamous Green Connector that tends to burn up on the 1K's...but I'm not sure if the 650's suffer the same fate. You can check the switch function easily when checking the GC so it's not a wasted effort to get to it for a check.
Unfortunately, you're probably hoping for a 'change the XXX' to fix the bike....and that's unlikely to happen. We know what it's doing (or not doing) but some things need to be checked to help figure out what is causing the problem. Double check what I mentioned above and if you don't find the problem at least we'll have a better idea where to go next. Don't worry....you can fix this!!
RecoilRob is offline   Reply With Quote
Old 12-29-2014, 10:02 AM   #8
realshelby
Supporting Vendor
realshelby's Avatar
Bikes: 2012 DL 650 , '14 BMW R 1200 RT
Re: C42 error code
One thing you can do is cycle the kill switch on/off till you hear the fuel pump kick on. Easier than toggling the ignition switch back and forth and seems to work better.
I lived with this same problem for years on my DL, didn't realize it was this easy to install the resistor! But, it never left me stranded because of it.
realshelby is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bike Won't start-FI light and C42 error code [email protected] SV650 Gen2 (03-15) Tech 13 05-09-2016 12:18 PM
05 sv650 fi error- code is c42 ryan1clancy SV650 Gen2 (03-15) Tech 6 02-29-2016 11:05 PM
Code 28 error, ECU isn't holding the code crazyhawk99 SV650 Gen2 (03-15) Tech 7 04-05-2011 11:24 AM
FI Light C42 Error red6rdr SV650 Gen2 (03-15) Tech 1 06-18-2010 08:36 PM
Error code C42 in dealer mode sbbsnewman Motorcycle Talk 2 03-12-2009 01:46 PM
1999-2009 SVRIDER.com.
