FI Light C42 Error - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 06-18-2010, 06:19 PM   #1
red6rdr
Junior Member
Bikes: 03sv650s
FI Light C42 Error
Used to be: eventually the FI light would stop blinking or by reinserting the key and wiggling it, the bike would not start with the FI light blinking=able to start.
When I put the bike into dealer mode I got this, C42 Ignition switch signal (IG switch signal) Anti-theft. Took it to two diff. shops and one stated it was the battery connection, they cleaned it up and started fine with no problems. But:
Current problem: FI light never stops blinking and bike can crank but does not make the normal "whirring" noise that occurs when turning the key to "on" position on the 2nd gen SVs. I've hooked the bike battery up to a car and doesnt help. Dash and head lights do come on.
Should I replace the ignition entirely? The keys are not OEM and I believe this bike was salvaged. Ive put on about 40k miles w/o an issue until now. Ive visually inspected the wiring and seems fine. First time I took it to the shop, they had rewired a burnt out wire near the front triple.
Thanks.
__________________
49 state 03 Copper Sv650s
red6rdr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-18-2010, 07:36 PM   #2
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
Re: FI Light C42 Error
There is a resistor inside the ignition switch which is connected between the Orange/Yellow and the Red wires (ignition harness) when ignition is turned on.
Since it was 'sorta working' if you wiggled the key, it is most likely a bad connection inside the switch.
If you would like to bypass the resistor in the switch, send me PM and I can give you the info on how to bypass that for about $1 cost. It's not that hard to find on the 'net, but still would rather not post it publicly.
D'Ecosse is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bike Won't start-FI light and C42 error code [email protected] SV650 Gen2 (03-15) Tech 13 05-09-2016 11:18 AM
05 sv650 fi error- code is c42 ryan1clancy SV650 Gen2 (03-15) Tech 6 02-29-2016 10:05 PM
C42 error code BIGBUGIN SV1000 (03-07) Tech 7 12-29-2014 09:02 AM
Error C42 bikejim SV650 Gen2 (03-15) Tech 0 03-26-2012 08:53 PM
Error code C42 in dealer mode sbbsnewman SVRider Motorcycling Forum 2 03-12-2009 12:46 PM
1999-2009 SVRIDER.com.
