Power commander vs dyno tune - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 04-10-2019, 09:52 PM   #1
Urban Kyng
Member
Urban Kyng's Avatar
Bikes: 2006 Suzuki SV650S
Miles Kms: 2621 Miles
So I have contacted a few shops, and some say to get both done, while others say a dyno tune with a custom map is all that is needed. I wondering what experiences people have had with either doing both or just one.
Mods that I plan on doing are, full leo Vince race mount exhaust, velocity stacks, cam swap, and maybe bored throttle bodies. My bike is an my sv650s.
And I'm planning to swap the front sprocket to a 16 tooth because the bike seems like 1st gear is short and on the highway, the bike feels like the rpms are pretty high, and it feels like it falls flat on its face anything past 80mph.
__________________
Torque moves you, horsepower keeps you going.
Urban Kyng is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-11-2019, 03:10 AM   #2
Craig380
Senior Member
Bikes: Blue 650 AL7, replaced my K6S (RIP)
Miles Kms: New bike: 1,610 and rising. K6S had 21,380 until it was killed by a patch of diesel
Re: Power commander vs dyno tune
I've no experience with using a PC, but to me it makes sense to do the mods you're planning (cams, exhaust etc) first, and then book some dyno time to see how the fuelling is after the mods. You can then dial in the fuelling etc as necessary using the PC.
On the gearing, it depends if you want acceleration or relaxed cruising. On stock gearing, a K6 is doing a genuine 6,000rpm at 80mph in 6th, and 6,700rpm in 5th, so you're nicely in the meaty part of the torque curve.
My own bone-stock K6S would quickly pull to peak power in 6th (a genuine 120mph, 130 on the speedo) on open roads with just a twist of the throttle, no need to drop a gear or crouch behind the fairing (I'm 170 pounds and 5'11" in normal riding gear). That's about all I'd get without crouching, but 120 is plenty fast enough for me on the roads.
Going up a tooth on the front sprocket will drop your rpm by about 6% and blunt the roll-on acceleration in the higher gears a little.
Craig380 is offline   Reply With Quote
Old 04-11-2019, 06:59 AM   #3
Urban Kyng
Member
Urban Kyng's Avatar
At 6 foot and 280lbs(was 318lbs so I'm getting there)the bike does reach 130 but takes forever.
And I know with the 16th tooth I'll lose some acceleration, but here in PA I normally cruise at 90 in the interstate for about 40 mins.
But I will go for the dyno tune first and go from there.
Thanks for the response.
__________________
Old 04-11-2019, 08:59 AM   #4
Junkie
Senior Member
Bikes: 06 1k
How are they planning on tuning it without the Power Commander? If they have a way of flashing the stock ECU, I prefer that to a Power Commander.
__________________
06 SV1000: 06 600 forks, Penske triple, Carrozzeria wheels, TopYokes triple, upright bars, RCS19, R6 calipers, OSF rearsets, full M4, Monster seat on custom subframe, JW Speaker Adaptive headlight
Junkie is offline   Reply With Quote
Old 04-11-2019, 11:11 AM   #5
Urban Kyng
Member
Urban Kyng's Avatar
One shop said they can custom tune the stock ecu, while a few other shops said that they need both to fully customize the map. I think they said tuning the ecu can only do so much, so a power commander is needed to fully adjust the maps and timing.
__________________
Old 04-12-2019, 08:59 AM   #6
Junkie
Senior Member
Bikes: 06 1k
tuning the stock ECU with Woolich or similar can do everything a PC can do and more
__________________
Old 04-12-2019, 11:12 AM   #7
Dieseler01
Senior Member
Dieseler01's Avatar
Bikes: 2007 SV650 (track)
Skip the PowerCommander... I am really not impressed with their reliability. I'have had them brick on my and customer support was HORRID and took months to get them to fix it.
Yoshi box, Woolich, TekaSFI can all be used to directly tune the stock ECU and be MUCH more reliable than a PC.
__________________
GSXR front w/ AK20s, Brembo, GPR steering damper,Penske, Marvic rear wheel, modified slipper clutch, Woodcraft, Yoshi full exhaust, 1g ex cam
Dieseler01 is offline   Reply With Quote
Old 04-12-2019, 10:49 PM   #8
Urban Kyng
Member
Urban Kyng's Avatar
I'll definitely have to check those out, the last think I want is for one to take a dump on me. Thanks for everyone's help
__________________
Old 04-13-2019, 04:01 PM   #9
twag4
Member
Bikes: 01 650s
Miles Kms: 22000
I could not find any other platform here in the USA other than power commander for my 2004 sv650S. It is Dino tuned using PCv
twag4 is offline   Reply With Quote
Old 04-15-2019, 01:31 PM   #10
Junkie
Senior Member
Bikes: 06 1k
Quote:
Woolich, Teka, etc let the dyno operator re-tune the stock ECU
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power Commander AT-200 Auto Tune chdrummerdude Parts For Sale 2 03-30-2016 05:18 PM
To tune or not to tune?? Greaseonmyhands SV650 Gen2 (03-15) Tech 4 02-05-2014 04:43 PM
Power Commander 5 Auto Tune NIB mk3vdub Parts For Sale 9 01-30-2014 12:19 AM
best place to get a power commander tune nols North Central 2 07-28-2010 06:54 PM
Power Commander III vs. Power Commander III EX (C.A.R.B. approved model) mozonian SV1000 (03-07) Tech 6 09-11-2008 08:27 AM
1999-2009 SVRIDER.com.
